Yes. Another low oil pressure thread. UPDATE 7/28
#44
Ok Well I tore the bitch down yesterday at work and this is what I found. Every counter-sunk bolt that holds the front cover of the oil pump was hand tight. Like not even tight enough to let my snapon ratchet, ratchet. When I was clearancing the pump to the cover I had it apart. and when I assembled it to test fit it I put the bolts in but failed to tighten them down.:ba ng:
I haven't gotten the car back together today so we will see how it fairs Monday. I will bet money that this was my problem and that when the motor got hot the gap in the cover increases enough for me to loose the pressure but it wasn't that enough of a gap that it couldn't build pressure.
Im just so upset at myself for something like that slip by. Im gonna switch back down to 5-30, remove the restrictor and see what happens.
Its a Mehling HP/HV pump.
#46
Thats what Im banking on. I took the 20-50 back but Oriley's doesn't carry it non-synthetic in 5-30 or 15-40.
Thanks for all the suggestions boys. Hopefully I wont need anymore after I get it all back together.
