PT88 Oil questions
Old Jul 22, 2011 | 01:02 PM
Tricked-Out-Toy's Avatar
Default PT88 Oil questions
Is anyone running a reducer on the feed side? I have a -4 feed and a -12 return and im getting oil blowing out into the exhaust housing.... I want to make sure its not a feed issue before replacing the seals.
Old Jul 23, 2011 | 08:50 AM
98Z28CobraKiller's Avatar
Restricted User
That combo should not be smoking. You either have a drain problem or the turbo needs rebuilt.
Old Jul 24, 2011 | 02:52 PM
Turb0Z28's Avatar
are you running a restrictor or just a plane old -4? they are $5 on ebay.
Old Jul 24, 2011 | 09:15 PM
No restrictor just straight -4 off the port above the oil filter. The -12 drain is sloped down at maybe a 20 degree angle for the first 12" and the levels off a little bit to about a 15degree angle before running into the oil pan above the fluid level
Old Jul 25, 2011 | 02:37 AM
Busy Mopper's Avatar
no u dont need a restrictor ive called and asked precision. also make sure u have at least a -10 for a drain.
Old Aug 31, 2011 | 12:10 PM
nasty_ss's Avatar
what kind of oil drain flange are you using and where did you get it?
Old Aug 31, 2011 | 01:26 PM
Eagle02's Avatar
^this
No restrictor! It shouldnt be smoking.
Old Aug 31, 2011 | 01:34 PM
Chicago TDP's Avatar
I had a similar problem with a good MP T70.
It would smoke after 80 PSI of oil pressure.
I put on a TC76 and no more issues.....T-Netics has a built in screen/restriction and specify -4 inlet, -10 oulet with no 90's...I have a 90 though...
