Swapping in the new ERL Powerplant...
Old Jul 24, 2011 | 01:40 PM
atomicfusion's Avatar
7 Second Club
Originally Posted by trans2000am
more info on motor?what happen to the lsx?
The LSX came out in 100% working order... it will be the backup motor for the rest of this year until ERL has time to build me a bigger better motor for next year. (oops, did I let that slip)
Originally Posted by Fbodyjunkie06
Man Mark your engine bay looks HUGE without all your hotside and coldside piping in the way. Is the motor set back in the car any?
No, it is in the stock location.
Originally Posted by Blown06
Did you get a chance to run the old motor with the new intake setup? did I miss that?
Yes we did, We made some tuning passes last Friday at National Trail Raceway. This intake setup was designed for the ERL mill by AllPro to mate up to the AllPro heads we will be running on the new motor, but I just couldn't wait so we put it on and tuned the motor for it. (just in case we need it later)
As for results, we were pretty happy with what we saw. My tuner hit the fuel changes right on the first shot (that has to be good) and we made 2 partial passes then started making full passes. We got tuned all the way up to 15lbs before the track started going away, but at 15psi the car was dead hooking and running 8.90. We turned it up to 20psi and the track wasn't ready for the power, we just blew the tires off. Unfortunately by this time the track was closing down, but we got tons of great data and are ready to run the LSX with the new Intake if we ever need to.
Originally Posted by JAX04
Glad you posted this up Mark! Wasnt sure you were going too, lol
Looking incredible man!
So what is the plan with the old motor now?? Tear it down and sell it off? or back up motor?
Back up for now, if you come to any of the races, you will see a complete long block valve covers to oil pan bolted to a transport stand in my trailer. If we have to, we will change it at the track.
Originally Posted by nmass399
Awesome, less weight up front!!! All pro's now, i am not sure what you were runnin before.
Before we were running the LS7 Style ETP heads. They worked well for us, but I am expecting the AllPro's to be even better!
Old Jul 24, 2011 | 01:46 PM
BLNLS1/RX7's Avatar
Hope you bring the car to Bowling Green in Sept. for the Holly LS Fest.
Old Jul 24, 2011 | 01:56 PM
7 Second Club
As for Details on the new ERL mill...
It is an LS2 based block setup to be 427CI...
6 bolt All Pro Heads
I don't want to release the cam specs, but it is bigger than I used to run
Solid Roller setup
Jessel Rockers
106mm Billet wheel Turbo
TH400 210 first gear
3.42 rear gears
315/60/15 rear wheels
Old Jul 24, 2011 | 02:02 PM
7 Second Club
Already registered.
Old Jul 24, 2011 | 02:21 PM
MUSTANGBRKR02's Avatar
Awesome build. What is the goal with this new setup? How much boost will you be able to run?
Old Jul 24, 2011 | 03:57 PM
nmass399's Avatar
Solid Roller setup
Jessel Rockers
3.42 rear gears
The engine build looks great man, i see your going with the 315's, what all was done to make them fit?
Old Jul 24, 2011 | 04:01 PM
Fbodyjunkie06's Avatar
Man I'd love to have an ERL motor.
I'll be happy when I get my LQ4 and am able to put forged pistons and rods in it, and have the 317's ported and polished. If I play my cards right it will have TF 220 as casts on it, I'd love to throw the whole parts book at it, but I just can't swing it right now.
Old Jul 24, 2011 | 07:01 PM
7 Second Club
Not much really.... just had to cut a bit out of the boxes in the trunk and clearance the lip of the fender a bit.
Old Jul 24, 2011 | 10:06 PM
nmass399's Avatar
That's good, i was thinkin it might take more to do it. I'm glad you got those on there, it should help get you closer to your goals. Lookin forward to seein what it will do at the ls fest.
Old Jul 28, 2011 | 04:14 PM
7 Second Club
New motor is in the car... Intial startup is done and the engine is cooling overnight.
Tomorrow we should start tuning!
Old Jul 28, 2011 | 04:22 PM
MY99TAWS6's Avatar
My car should be fired up tonite or within day or so also.
Old Jul 31, 2011 | 08:48 PM
  #32
7 Second Club
Old Jul 31, 2011 | 08:53 PM
  #33
JAX04's Avatar
Awesome! Time for vids!!!
Old Jul 31, 2011 | 08:58 PM
  #34
SHovV's Avatar
that is THE ugliest **** i've ever seen. you make me sickjk
Old Aug 1, 2011 | 07:46 AM
  #35
MY99TAWS6's Avatar
What a beautiful and interesting look engine you have there! So can you change the spark plugs without taking off a bunch of stuff ?
Old Aug 1, 2011 | 08:13 AM
  #36
Fb0dy0nly's Avatar
almost need sunglasses to work in that engine bay with all that shininess everywhere. Bet you cant wait to get that thing to the track now...
Old Aug 1, 2011 | 12:09 PM
  #37
LS1NOVA's Avatar
Who did the coating and what temp is it rated to? Engine looks amazing!
Old Aug 1, 2011 | 02:54 PM
  #38
gnx7's Avatar
I assume you don't run an air filter on that turbo?
So you went 7's with stock rocker arms with the upgraded trunions on the last motor? Wow.
Old Aug 1, 2011 | 03:01 PM
  #39
Are you using a crank trigger and a distributor mark?
I ask because I see the timing light, but I see coil packs, or are those just brackets?
Old Aug 1, 2011 | 04:20 PM
  #40
7 Second Club
That is just polished, no coating yet...
Yep... We will see what we can do with a solid roller setup soon.
We do have a timing point that we use to compare to the stand alone computer. We are running the coil packs still.
