Which meth system and why?
http://www.alcohol-injection.com/dvc...age-2-305.html and chepper
Devils Own, "Components are engineered to withstand 100% mixtures for normal expected life of product"
Snow, "all components of Snow Performance systems are designed to be able to handle pure methanol"
Alky Control, "A progressive system designed once again for 100% methanol"
If I'm shooting for slightly less than 600rwhp and 10psi boost, are all the kits below compatible?
What's the difference between a Devils Own 5151 and 5106?
What's the difference between a Snow 20010 and 20012?
Devils Own 5151 LS1-7 Stage 2 (progressive)
$400
http://www.alcohol-injection.com/ls1-7-stage-2-49.html
Devils Own 5106 DVC-30 Stage 2 (progressive)
$375
Snow 20010 Stage 2 Corvette Boost Cooler (progressive)
$423
http://www.snowperformance.net/product.php?pk=57
Snow 20012 Stage 2 Corvette GM MAF Boost Cooler (progressive)
$433
http://www.snowperformance.net/product.php?pk=55
Alky Control AC-C5 Kit (progressive)
$600
http://www.alkycontrol.com/
http://www.eastcoastsupercharging.co...hol%20Kit.html
I ve run devils in lots of stuff. I ve run 100 % for testing, buthave always settled on 50/50. You get better cooling from water.......so unless you need the fuel, and are out of injector, then 50/50 or even straight water id best. There is a thread on here somewhere, that a guy did on here on his engine dyno.....straight water won with the right tune.
As for pumps etc etc. They all use the same Shurflo based pump. So there really wont be much difference.
http://www.alcoholinjectionsystems.com/index.html
$400
$375
$423
$433
$600
