Fuel system for TC78 on LSX Mustang
Gathering parts for my turbo build. So far i have a goal and a turbo. Id like to see 700 whp, through a TH400, if the turbo will do it. I have a TC78 turbo, Im still looking for my 6.0 block which i will be running a aftermarket piston and rod with stock crank. 243 ported heads, a turbo cam, ls6 intake. SOOO while im in search mode figured i should ask what fuel system or parts you think would work well, sorta cheap if possible. I was thinking going with a external pump and sump my tank. I still have the stock 87 mustang tank with 255 walbro pump in it now set up for LSX. I was thinking 80lb injectors? external pump? fuel pressure regulator? any input would be great so i can start gathering these parts. Thanks
