6061 Intake Elbow????
Old Jul 25, 2011 | 01:33 PM
dreamls1's Avatar
Default 6061 Intake Elbow????
Hey, is anyone useing the stock throttle cable with the 6061 intake elbow? or do i have to run an aftermarket cable?
Old Jul 25, 2011 | 02:49 PM
westtexasbuff's Avatar
You can use the stock one, just make sure when you are buying it from their website to choose to include the throttle bracket.
Old Jul 25, 2011 | 03:46 PM
dreamls1's Avatar
I got mount. It's not even close to the TB!
Old Jul 27, 2011 | 07:30 AM
dreamls1's Avatar
Anyone?
Old Jul 27, 2011 | 09:28 AM
Stock throttle cable:
Old Jul 27, 2011 | 11:49 AM
trans2000am's Avatar
mine came with a metal tab welded on the side for the cable
post a pic
Old Jul 27, 2011 | 11:53 AM
dreamls1's Avatar
well do did mine, but its set WAY BACK. The throttle would be wide open.
Old Jul 27, 2011 | 11:55 AM
dreamls1's Avatar
Old Jul 27, 2011 | 04:20 PM
looks like the same one i got, i bought a new cable from sdpc cause i deleted my cruise and traction control
Old Jul 27, 2011 | 04:28 PM
dreamls1's Avatar
What's the part
number? Did it fit good?
Old Jul 27, 2011 | 10:03 PM
http://www.hawksthirdgenparts.com/98...ablenewgm.aspx
Make sure to get the one without TCS.
Old Jul 27, 2011 | 10:32 PM
dreamls1's Avatar
How is this different than the stock cable?
Old Jul 27, 2011 | 10:40 PM
It's not, that is the stock cable... you asked for the part number, but I couldn't find it.
Old Jul 27, 2011 | 11:21 PM
corpserodeo666's Avatar
Here is the 12565560 you can get from http://www.gmpartsdirect.com/ its like 26 bucks.
I just used the nicer looking Lokar one http://www.summitracing.com/parts/LOK-TC-1000LS1U/ and than I just adjusted it to fit correctly. If you buy this one you would need to get washers to go on the firewall so it does not fall through.
Old Jul 28, 2011 | 11:54 AM
dreamls1's Avatar
Cool, and you have the same intake elbow and mount in the same location?
