how to install anti surge valve?
i have a lsx procharger d1sc kit. i have the black procharger anti surge valve and i cant tell how it is supposed to be installed. I dont know if I'm supposed to have a special flange or fitting or what? Can anyone help me with this? Maybe some pictures would help too?
In the installation manual they have pics of valves mounted on flanges, but my valve appears to be a different style than what they are showing.
please help.
please help.
I think I have the proflow valve, does this sound right? I'm just not sure how its supposed to be plumbed into the tubing? Are these valves noisy? When,m what throttle conditions?
LS1Tech Sponsor
please help.
please help.
See if this pic helps you out, shown is the Pro-flow valve.
These valves are not too noisy. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Your surge valve (optional) should be positioned between the blower and the intercooler (or between blower and throttle blade for non-intercooled kits). If you purchased this option you have a mounting flange and hardware to plumb the valve into your system. If you purchased the race valve, it will connect to the mounting fl ange using (6) #10 x 3/4” SHCS’s. There is also an o-ring that will go in the groove in the mounting flange.
You will need to supply a vacuum source for the surge valve to operate properly. On EFI vehicles, a source after the throttle blade is mandatory (the intake manifold is a good vacuum source). For carb vehicles, a vacuum source after the carb is neccesary. For vehicles with a brake booster, tee into the brake booster vacuum line. Run a piece of 1/4” hose from your vacuum source and plug the hose into the bung located on the surge valve.
The above info is taken from the ProCharger Transplant Manual. You need a bung coming out of your tubing for the valve to clamp to. The picture here is of a tube for the '98-02 F Body system, for the bypass valve to connect to.
Hopefully this helps you out. Bob
__________________
