My turbo build. 5.3/t56 with a GT45
#61
#62
Sorry if you posted it already but what where some of the big issues? does the 5.3 block support the fbody front accesories ok? any need to tap/drill anything? looking to do this setup also.
any short...what were the big trouble areas?
#63
F body accesories fit fine...it's essentially the identicle motor. On any iron truck block you will need to tap the boss on the block where the upper alternator bracket bolt goes. Other than that, your golden. Everything else is identicle.
#68
All accessories worked fine, except the alternator that has already been mentioned which would be an easy fixed.. however i moved the alternator up for clearance for the truck manifolds so i didnt have any issues
I will get some more vids soon! installing a Twin disk clutch hopefuly this weekend and also trying to figure out my high vacuum issue, possibly bad turbo or something stuck in my intake manifold
#70
behaves very well! drives like a stock car! You would never even knew it was turbod until you got into the throttle
Also in this video the car is way underpowerd as i pulled my intake off because i noticed a loss of power and found my FAST intake mas missing few bolts and had actually was coming apart
#72
its been dynod and number have been posted, but i guess you skipped over them
451hp/502 tq on 6 psi of boost. Stock cam and heads
in the process of installing a mcleod RXT street twin disk right now, next i am gonna install my deatsch werks fuel pump, and 93lb injectors, custom cam, and heads
hoping to make 600/650 on 6 psi with the heads and cam setup, hopefully 700hp with 10-12psi
#75
Obviously not too restrictive to make 450+/500+tq on 6lbs with stock cam and heads junk yard 5.3 with just 6 ps. And my bend radius is much better than this 1200hp+ lambo's downpipe setup, so it cant be too bad.
#78
its wrapped on the back side of it where it comes close to the plug wires, dont see a piont in wrapping any more of it. i daily drive it for 10,000 miles now and havent melted anything . so i think it will be fine
#79
Im starting my build and it's DAMN near identical, stock 5.3 with the exeption of LS6 cam/intake/injectors....
Im hoping to be around the same power as you, later on i will throw some 317's with springs and upgrade the fuel setup!
