EPS 234/246 with boost?
Old Aug 3, 2011 | 09:51 PM
dre2013's Avatar
Default EPS 234/246 with boost?
I have an EPS 234/246 .602/.607 111LSA cam. I'm running an LQ9 stock bottom end w/ ARP bolts, and stock 317 heads w/ dual springs, LS6 intake manifold..CR of 10:1. I am going to be purchasing a Procharger D1SC in the next few days, and was wondering what everyones' opinions on the setup is? do you think this cam will work good with 9-10lbs boost? thanks
Old Aug 3, 2011 | 10:14 PM
Zmg00camaross's Avatar
I have no opinion or advice sorry, But do you have any numbers with the cam? Have this cam waiting to go in.
Old Aug 3, 2011 | 10:32 PM
dre2013's Avatar
sorry no numbers with it, i havent installed it yet. was planning on an all motor + nitrous setup but i said screw it and decided to go FI.
Old Aug 3, 2011 | 10:38 PM
blue00ZZleeper's Avatar
If its a stock bottom end LQ9 with 317's the compression isn't going to be 10.0:1...it'll be lower then that. Are the heads decked a lot?
Old Aug 3, 2011 | 10:44 PM
dre2013's Avatar
a completely stock LQ9 has a CR of 10.0:1, and thats what im running with the exception of a cam,rod/headbolts, etc. 317's are the stock heads for LQ9's
Old Aug 5, 2011 | 08:22 PM
dre2013's Avatar
anyone?
Old Aug 5, 2011 | 10:00 PM
postal14's Avatar
superchargers like more duration on the exhaust than the intake since the intake side is being force fed. If you look at the specs on it I could easily see this cam being addvertized as a supercharger cam. The LSA may be a little tight but that will make it sound a little meaner also. It will probably run like a raped ape once you get a few rpms in it.
Old Aug 5, 2011 | 10:02 PM
postal14's Avatar
BTW do you know what intake centerline the cam is installed at?
Old Aug 5, 2011 | 11:11 PM
TWS's Avatar
TWS
Probably not a bad cam to run, but it seems the most popular and effective FI cams have a wider LSA like 114 or 115.
Old Aug 7, 2011 | 10:52 AM
KC Henry's Avatar
That is the exact same set up I have (even with ARP's and LS6 intake lol), I am eager to finish it up to see what it puts down N/A. I am hoping for 400+ at the tire through TH400 with a 4500 stall and stock 10 bolt.
It will be interesting to see what your FI version puts down.
Old Aug 7, 2011 | 11:09 AM
^^^ damn no one has numbers with that cam. As I have mine sitting in my room lol. I agree with TWS the FI induction cams I have seen are wider LSA. But I bet it will still make good power.
Old Aug 7, 2011 | 08:23 PM
KC Henry's Avatar
The cam seems to do well in a 346ci LS1, see post# "134" https://ls1tech.com/forums/dynamomet...results-7.html
Old Aug 7, 2011 | 08:55 PM
Right on there KC.
