KY turbo Build: Stock Btm End
Figured I would start the build thread. The kit will be here in September from Josh at Kentucky Turbo. Great guy to deal with by the way. The car is a 02 Black SS m6. It was a cam only car with 4.30s, etc in it. Here are the particulars of the build with a couple of pics.
Turbo:
6.0L Manifold Turbo Setup:
-2.5” Charge Pipes with a T4 Flange and Integrated Waste Gate mount and
narrow band O2 bungs
-3” Down Pipe with a Wide band O2 bung run over the k-member
-Precision Billet PT76/75 Turbo
-Precision 46mm Waste Gate
-Tial Q 50mm Blow Off Valve
-Front Mount Intercooler 31”x12”x4”
-Aluminum 3” Intercooler Pipes with Integrated BOV mount
-4 Ply Silicone Couplings
-T-Bolt Clamps
Internals (completed):
z06 cam
PAC dbls
7.40 pushrods
Stock 241s (never been off)
ls6 intake
Stock TB
Fuel (Haven't started yet):
e85
Lonnies dbl pump kit (need to buy here in a few months)
Possibly the fuel line/rails kit
80lb injectors (need to buy)
Boost reference regulator, etc. (need to buy)
Suspension (completed minus gears)
Dana 60
3.73 with spool (just need gears)
MWC dbl adjustable suspension
Strange coilovers in the front
Strange dbl adjustable in the rear
Clutch (completed):
Monster Stg 3 (6xxx) miles
Mcloud Bellhousing
Steel driveshaft
Tick MC
All I can remember right now. The goal is to run 11.30s on DR radials and put down 500 rwhp on Fuel Injections dyno. Not real worried about putting out record numbers, just want it reliable until I can build a motor. Here are a few pics of what the car looked like at the San Antonio Big Money Bash, getting washed before going under the knife and some motor pics with progress. Will update as everything gets completed.
Turbo:
-T-Bolt Clamps
z06 cam
PAC dbls
7.40 pushrods
ls6 intake
Stock TB
e85
Dana 60
Clutch (completed):
Mcloud Bellhousing
Steel driveshaft
Tick MC
The last pic is of the oil drain. Saw Tally Transam did it and had goodluck. Didnt want to have to pull the pan so I hoping this will work out ok. Motovative Solid mounts will be going in next week as well. Post up any suggestions you have as I am new at FI.
In the bag is Modular turbo's alternator relocation kit.
I took the paint off the coil brackets and had them chromed. They will be going on black wrinkle painted valve covers.
Breather can with 2 bungs
Motovative Solid Motor mounts.
Hell yea man my car has a twin!!!
You will no doubt make 500rwhp with that set-up.
Sounds identical to how my car's life started. Stock Bottom end, PT76GTSH(older model 76/75) and M6 but with a 12 bolt.
I want to try E85 so bad, I have the fuel system for it I just need 80#'s probally instead of my 60's.
Yea..I need to get in touch with lonnie and see what he thinks about it. Maybe in the next couple of days I will get around to it. Not in a huge hurry with the car. Just want to get it out around January to enjoy it in the cool weather. Yea, I lucked out with a station a mile from my house with e85. Figured that would allow me to keep the 241s on the car for now. Your build has turned out really nice. I am jealous of that 4l80e you have.
Just wanted to update the thread a little. Hotside will be here next week and hopefully the rest after christmas. Should have the car out on the road in a month or so. I am hoping for February 1st.
I will update this thread with some more pictures this weekend.
LS1 Tech Administrator
Great looking build. I've got lots of turbo experience so if you need help with tuning or tricks, give me a shout. The other guys you mentioned are top notch too.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Couple of new pics. Hotside got here yesterday. Hopefully will have it on the car on Tuesday after I purchase manifolds.
The 2nd pic I started looking at routing the belt with the new power steering lines from modular turbo. This was the best route because of where the turbo drain is. Hopefully this will work out.
The 3rd pic is the modular turbo alternator pic. I don't like the color and after I get the car running/tuned, I will pull the bracket off and paint it black. I will also be purchasing a chrome alternator hopefully.
Josh at Kentucky said the turbo and cold side should be here next week.
![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
hey did you hear I picked up that built tranny and a 3600 stall....I cant wait! if it all works good with the trans the next step will be saving up for a turbo also.
