what do you guys think?
Old Aug 16, 2011 | 10:54 AM
THE-CHAD's Avatar
I have a pretty good tuner available for the blow through so i hope that will help what are the stock intakes good hp wise on these things
Old Aug 21, 2011 | 12:23 PM
THE-CHAD's Avatar
Ok guys I think I am going to scratch the whole blow through thing and opt for fuel injection
running the victor jr., efi intake elbow, and 90mm throttle body. I was wondering what size injectors i should use for boost; I was thinking 75lb injectors from fuel injector clinic. Is this to much or do i need more injector? Looking for 15psi of boost. P.s. will be running e85.
Old Aug 21, 2011 | 01:37 PM
CarsandWomen's Avatar
I dont think 75's will be big enough at all, E85 requires a lot more volume that gasoline. If you run pump gas then theyll get you there but for E85 I would go bigger. You could always jack up the fuel pressure with boost too, Im not as well versed with E85 as most but im lookin for 600hp with 65lbs and I know ill be generally close to there limit
Old Aug 21, 2011 | 02:41 PM
THE-CHAD's Avatar
thank you what size would you go for 95lbs maybe?
Old Aug 22, 2011 | 12:01 AM
I wont speculate, you need the opinion of someone who has delt with it more.
