front mount pictures & video's
Turned it over last weekend. Fixed the overheating issue since then.
my set up should be as listed:
317's w/dual gold springs
ls6 cam
spoolin performance t4 flange truck manifold kit
GT-91mm 1.08ar
cxracing itercooler
twin walbro's (already have one from previous set up just need to get the second and the fitings)
ls6 intake
80lbs injectors
the only thing im not really sure on is which gear i will be running, or which BOV OR Waste gate ill be running
Made 444 rwhp 414 tq N/A
Bre 224 n/a cam (single pac 1518 beehives, valve float above 5800 rpm)
Ported fast 85
KYTP Truck manifold setup with Precision 76GTS on 8lbs of boost
Alky Control Meth injection with 100% meth and 92 pump gas
3700lb + raceweight
MWC Fab 9" with 3.50 Gears
T56 with Mcleod RXT Twin (amazing clutch)
26"x11.5-15 M&H Cheater slicks
Stock slp bilstein shocks with lowering springs
Stock Lower control arms
Bling Bling
Push to connect fittings
Consists of Summit 15" wheels, powdercoated gold to imitate weld magnums.
15x4 up front with 185/65/15's and 15x8 out back with Hoosier 275/50/15 DR's.
Super sick it's a small world!
http://www.youtube.com/watch?v=L0SO_aFL2Ys
