My D1SC will be here on tuesday!
. Im gonig to have mike norris tune it also. Mods are in my sigIll be really happy if the car makes 500-525rwhp. Think ill hit my goal on 7-8psi?
I am going to look into seeing waht the cost would b to have a forged rotating assembly installed into my block vs the price to buy a pre-assembled shortblock from TSP.
Comments welcome!
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Here is a link to the ProCharger front mount that I sell. This front mount requires the use of the race valve.
http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm
If you want to see a copy of the ProCharger front mount installation instructions, send me an e-mail to brutespeed@gmail.com requesting them and I'll e-mail them to you.
Thanks. Bob
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Yea that was the same kit i was gonna go with. "TheAlchemist" seemed to have pretty good luck with his.
Will the big red blow off valve decrease my boost any? I heard it will. I just want it for the sound.
I was also told that i could run the BOV that comes with the kit, and just vent it to the atmosphere instead of recirculating it back into the charger if i wanted it to be louder.
So until I get it going. First thing I gotta do is replace the clutch. Then I have to buy injectors and gauges. Then set up an appointment for a tune.
