which intake gasket for lq4 boost?
Old Aug 20, 2011 | 09:46 PM
jks67ss396's Avatar
Default which intake gasket for lq4 boost?
Hey guys
Hows the felpro stock type gaskets work for boost on an lq4? The black plastic with the orange orings?
Do i need the metal permadry type intake gaskets or something else entirely?
looking at 15psi boost.
thanks guys!
Old Aug 20, 2011 | 10:09 PM
HydroStream6's Avatar
Gm mls. Ls9 is all the rage right now. 7 layer.
Old Aug 20, 2011 | 10:49 PM
jks67ss396's Avatar
sorry man.. looking for intake gaskets. not head gaskets. already got the heads on
just looking for thoughts on the intake gaskets... stock or something else?
thanks
Old Aug 21, 2011 | 08:26 AM
jks67ss396's Avatar
bump up
Old Aug 21, 2011 | 10:35 AM
stevieturbo's Avatar
If you're using a stock intake, with the stock o-rings, why would you even consider downgrading to anything else ?
Old Aug 21, 2011 | 10:50 AM
jks67ss396's Avatar
downgrading? not quite sure i understand.
Ill be running around 10-15 lbs of boost with the stock lq4 plastic intake
heres my options:
1) use the stock type plastic gaskets with the orange orings
2) upgrade to the metal gaskets with orings (these are the permadry ones)
3) something else even better
so id like to know: for boost, is the stock plastic type fine or do i need to buy the metal perma-dry type or something else
thanks
Old Aug 21, 2011 | 02:09 PM
Well, how can you upgrade from something that works perfectly and is effectively free ?
Old Aug 21, 2011 | 02:27 PM
dschmittie1's Avatar
I am assuming since you said plastic with orange rubber you are using a truck intake. (which the gaskets are totally different than ls1/6 gaskets)
I would recomend getting some new GM gaskets they updated them the Orange ones have issues and the new ones are green rubber with plastic And they work really well.
Old Aug 21, 2011 | 02:30 PM
Fair enough, I assumed the truck was same as LS1/6
Old Aug 21, 2011 | 05:18 PM
jks67ss396's Avatar
so the plastic/green rubber ones work great for boost?
yep, truck manifold.. lq4
thanks
Old Aug 21, 2011 | 10:44 PM
jks67ss396's Avatar
Can anyone confirm the green oring gaskets (89060413) will hold at 15 psi?
thanks guys
Old Aug 21, 2011 | 10:54 PM
SirNemesis's Avatar
Yes, green ones here at 15psi+, no issues.
Old Aug 21, 2011 | 10:56 PM
jks67ss396's Avatar
thanks man!!
Old Aug 21, 2015 | 02:53 AM
Claydos's Avatar
hey man, looking for the same gaskets in Brisbane, just wondering where you got yours from? also how is your truck/car running? Any other tips? I am trying to run an ls with nnbs truck manifold in a patrol.
thanks
Old Aug 21, 2015 | 08:43 AM
thanks
Just use the factory gaskets, they rarely need replaced.
Old Aug 21, 2015 | 09:04 AM
JoeNova's Avatar
Restricted User
The number of people that far overcomplicate their setup is almost painful anymore.
Old Aug 21, 2015 | 10:35 PM
Claydos's Avatar
Thanks for the straight up useless information team. Simply put the standard o-rings don't f*cking work on the truck manifold. If they did I wouldn't be f*cking asking the question. I brought a truck manifold and it came with the manifold and fuel rail, thats it. Hence the quite simple question asking where he got his gaskets from.
Here's an idea from now on if you don't have the answer don't post a reply
Old Aug 22, 2015 | 01:39 PM
Or another idea...find out why the OEM gaskets dont work for you...but do work for everyone else ?
Old Aug 24, 2015 | 04:16 PM
forcd ind's Avatar
Ask stock48 on here what he is using, he is making serious power with a truck intake
Old Aug 27, 2015 | 04:48 PM
rryan5429's Avatar
Default intake gaskets
I run a stock truck intake with just factory gaskets. I'm on 17psi and 800 to the wheel. Don't have a ton of time on it yet. But it hasn't been an issue to this point.
