T-72 5.3L what A/R?
I`m not worried about top end power, I know I will make 500+ RWHP no matter which housing. I had been leaning toward the 0.68 so that it will spool quicker, but now that I was reading about it there seems to be a lot of people saying to get a 0.96. Will the .68 choke that motor? Will it be so restrictive that at a 2500rpm cruising speed it kills fuel economy?
runs a split housing 72 (.96) on a 5.3 with a zo6 cam, 317's, and a rossler 4l80e.
Its hard to drive out of boost meaning its always on the verge of boost driving easy. I foot brake it to about 14 psi on the line and it runs about 17 or 18 psi on 91 octane with water meth (devilsown) . Figuring its 6300 lb race weight, it makes about 700 awhp. Its a daily driver and boost it instant, just think about it and its there.
It runs 12's....and has for two plus years now.
I do run a quick spool valve on it.......worth about 500 rpm on boost onset. So it runs a tighter convertor (2800).
e 85 would be great, but the van has maxed the turbo....maxed the single 340, and maxed the 60 lb injectors.....so e85 isnt in the cards with out a lot of changes.
