Twin intercooler owners take a gander
What will happen to the intercooler if you catch something on the road? You might consider weakening the flange so that it will break off if you hook something on the street.
Intercooling below ambient with an air to air intercooler isn't possible unless the intercoolers were chilled below ambient before the test and if that were the case it wouldn't last long and it would be the absorbsion of heat into the IC body and not heat exchange to the atmosphere so either your ambient reference is off, or your data logger isn't set up properly.
I'm curious what pre and post intercooler temps are with what ambient conditions. If you have this data you can figure your IC efficiency.
This is part of an article in GMHTP where a ProCharger engineer participated in a install of ATI's 4.5" intercooler system complete with 3.5 / 4.5" comparison of IAT's so you can see where you stand.
http://www.gmhightechperformance.com.../photo_31.html
Complete IC install article.
http://www.gmhightechperformance.com...ooler_install/
Keep up the good work.
