Cam suggestions for turbo LS1
specs:
5.3 block bored to 3.905 (LS1)
317 heads, mild valve job
LS1 intake and TB, (gonna try to pick up a vic jr)
stock crank
forged oliver rods
forged wiseco pistons
head,main studs.
LS9 head gaskets (seems to be what everyone is using)
stock rockers w/ trunion upgrade.
power goal is around 700fwhp on a good SD tune with maybe 10-15 PSI
possibly using a midsize T4 frame 80-85mm turbo. (havent sorted out the turbo selection yet, goal is to get the motor finished up firts, worry about boost later)
and dont bother telling me to use the search button. Im asking what would be the better choice, im 90% sure most of you will say custom grind, but i dont think i can shell out the $$$.
Thanks in advance guys.
i love a cam that hits hard as hell,i did run the largest off the shelf cam from comp in my LT1 and it was awesome, but i also want it to perform, and eventually ill crank up the boost to see what happens.
I have a build in the works and it is what I will be using.
VA speed has some really nice F/I cams also that would be perfect for what you want. Look into the VTC2 from VA speed.
Don't get a blower spec'd cam. Wide traditional splits in duration aren't favorable for cylinder filling and building boost at low rpm's. They may sound nasty at idle, but I'd rather build boost way sooner than the guy in the lane next to me.
