F1c and 8 rib ?
Old Aug 27, 2011 | 12:44 PM
CyaPussy's Avatar
Default F1c and 8 rib ?
Is anyone running an f1c with an 8 rib bracket Aster or Sdce or is this just asking for trouble?
Old Aug 28, 2011 | 07:34 PM
CyaPussy's Avatar
bump.
Old Aug 29, 2011 | 09:24 AM
dans776's Avatar
Depends how hard you want to spin the blower. What are you looking todo with the combo?
Old Aug 29, 2011 | 10:06 AM
LS1RedZ's Avatar
I remember Aster telling me he had a few guys running F1 head units with the bracket and them doing alright. Ive only heard of Inspector12 running a F1R with some flex issues. When did you pick up a F1C?
Old Aug 29, 2011 | 11:57 AM
mikep2002's Avatar
oh boy the bigs dogs coming out...
Old Aug 29, 2011 | 04:19 PM
CyaPussy's Avatar
What im intrested in is a stroked ls3 with stock heads for a little while. I would imagine f1 whatever with about 15lbs should be more then enough so I should be able to keep stock heads. I just heard f1c runs a little cooler then the f1a im not intrested in meth so less heat the better. Just putting some ideas together for right now.
Old Aug 31, 2011 | 09:41 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm
Check out the dyno graph that can be found at the link here for our blower cam. This CTS-V has an F-1A, and makes plenty of hp and torque. For your combination I would go with the F-1A. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Sep 1, 2011 | 01:26 PM
CyaPussy's Avatar
Bob, will the f1a run hotter then the d1?
Old Sep 1, 2011 | 01:32 PM
LS1Tech Sponsor
From what I have seen, the F-1A will run cooler at x amount of boost than a D-1SC at that same boost level. We would not of made as much horsepower in the above dyno graph with an D-1SC as we did with the F-1A. Bob
__________________
