Heads or Motor gone
Old Aug 28, 2011 | 06:49 PM
maxgee's Avatar
Default Heads or Motor gone
22 to 25 psi b/c WG failed to open.
Won't be able to run full diagnosis on the motor for two weeks.
I don't see evidence of coolant in oil, was too hot to check.
Smoke coming out of breather is white.
What do you guys think motor or heads lifted?
http://www.youtube.com/watch?v=Zdaea...e_gdata_player
.Update
Number 7 ringland is broke
Old Aug 28, 2011 | 06:53 PM
black98ws6ta's Avatar
More then likely hurt the pistion...but all kinds of things can happen. Was it missing?
Old Aug 28, 2011 | 07:07 PM
maxgee's Avatar
No miss
Sounded a little like a diesel truck to me but that could be me looking for a problem.
Old Sep 11, 2011 | 06:34 PM
maxgee's Avatar
Pulled the heads and dont see anything definitive on what ghe causd of the white smoke out the oil filler. Couple of friends looked and see one small area on driver's side HG that looks suspect. Going to get nre HGs and put it back together this weekend.
Old Sep 11, 2011 | 07:55 PM
crashinaz's Avatar
Leakdown test would have told volumes, but that's a decent volume of crankcase ventage. I'd look VERY closely at each bore for irregularities then bring each piston up to TDC and do your best to look for a cracked top ring. Best you can do at this point. Good luck.
Old Sep 11, 2011 | 11:30 PM
Ironmancan's Avatar
How much boost were you setup to run before the spike? How long did it take you to notice the spike?
Old Sep 11, 2011 | 11:52 PM
maxgee's Avatar
Maybe a second.
Just confirmed that oil is on the threads of number 7 plug and looking into the threads of the 7th chamber on the head, oil can be seen. So looks like i cracked the common no#7 ringland.
Now i gotta break the news to the wife.
Oh well
Old Sep 12, 2011 | 10:32 AM
Ironmancan's Avatar
Ugh thats sucks how much boost were you running before the spike?
Old Sep 12, 2011 | 11:04 AM
Josh@Lashway's Avatar
all i want to know is how was 1000 hp for one second?
Old Sep 12, 2011 | 11:49 AM
TurboAv's Avatar
If money is tight, just throw a 4.8 or 5.3 in it for the time being.
Old Sep 12, 2011 | 06:06 PM
maxgee's Avatar
10psi
Short lived glory!
Old Sep 19, 2011 | 01:32 PM
maxgee's Avatar
Number 7 ringland. The price that broke off feel out when the piston taken out. The cylinder wall was still smoothed, had hone done to seat the new rings. Everyhk g is back together, just gotta put some miles fondest the new rings and back into boost I go.
Old Sep 19, 2011 | 01:48 PM
1fast bird's Avatar
Glad you got it fixed up. What wastegate were you using? Was it a vaccuum line that came off to cause it not to open?
Old Sep 19, 2011 | 01:56 PM
JAX04's Avatar
Glad you got her fixed man! That looks painfully familiar, lol.
Only difference, mine was #5 top ringland, and it was a big *** chunk like that. I shouldve just slapped a new piston in their and re ringed it.
Glad you got her back together man!
Old Sep 19, 2011 | 02:58 PM
maxgee's Avatar
Tial, just needed some servicing. The valve had build up of some rusty water residue on it. It was a few months since I pushed past 10psi thus the WG hasnt been opened probably since April at my last track outting
