What TB for proflow?
Old Sep 3, 2011 | 05:34 AM
KrisXpc's Avatar
Default What TB for proflow?
Friend of mine just added a proflow to his APS combo and his 90mm TB will not match the bolt patterns..
I thought this was really odd... and wanted to inform those looking to make the swap..
Old Sep 3, 2011 | 06:54 AM
nodrok's Avatar
i used a nick williams 92 on a proflow xt. Dont know if this helps.
Old Sep 3, 2011 | 05:06 PM
KrisXpc's Avatar
It does..
My friend is using a PRC 90mm and only the top 3 bolts are fitting...
Old Sep 4, 2011 | 01:17 AM
black98ws6ta's Avatar
Edelbrock also sells matching throttle bodies.
Old Sep 4, 2011 | 02:26 AM
buick_lsx's Avatar
they have 2 diff pro flo's...they also have a 1/4 spacer/adapter for other throttle bodies
Old Sep 4, 2011 | 07:23 AM
nodrok's Avatar
last i checked edelbrock only made a drive by cable TB/ I needed a DBW.
Old Sep 4, 2011 | 08:57 PM
KrisXpc's Avatar
So use any DBW TB ..
Old Sep 4, 2011 | 10:22 PM
nodrok's Avatar
Im not saying any will fit. But i do believe most will fit. I gave edelbrock a quick call. Their support is good over the phone. Or better yet call someone like scoggin dickey they deal with proflows as well as all the aftermarket TB's. Theyll tell you witch one will work. Good luck
Old Sep 5, 2011 | 12:51 AM
tripblackls1's Avatar
i have a rev extreme 95mm throttle body on mine , i just had to elongate the bottom two holes
