Boost spike question
Old Sep 11, 2011 | 04:17 PM
SuperZ's Avatar
Default Boost spike question
I'm currently running a tial 46mm wastegate.the gate has a 7 psi spring in it but boost goes to 12-14 psi then the gate opens and pulls boost down to 7.
I've tried running different size line from the fitting on turbo to side waste gate port but nothings helped.
The gate seems to be either sticking or not getting the vacuum flow to it. Any ideas?
Old Sep 11, 2011 | 04:19 PM
SuperZ's Avatar
On a 3 psi springs it spikes to 6 then open after and will hold at 3
Old Sep 11, 2011 | 04:26 PM
JAX04's Avatar
certainley sounds like its sticking or torn. Have u inspected it yet?
Another question, is this a new setup?
Old Sep 11, 2011 | 04:34 PM
SuperZ's Avatar
Yes new wastegate.
So the rubber ring seal under the cap can stick ?
I could put some oil or something on it possibly so it doesn't stick if that would help
Old Sep 11, 2011 | 04:35 PM
JAX04's Avatar
I mean the whole turbo kit, it is new?
If its brand new, i highly doubt it would be torn or ripped.
Old Sep 11, 2011 | 04:45 PM
SuperZ's Avatar
The kit and gate are new
I have changed springs a few times though. They sent me wrong spring first time so I had to change it. I don't think it's ripped. The cap does kinda stick to rubber seal when bolts are out when taking cap off to change spring
Old Sep 11, 2011 | 05:40 PM
98Z28CobraKiller's Avatar
Restricted User
Sounds like bad WG placement. Got any pics of how it's plumbed?
Old Sep 11, 2011 | 08:13 PM
Nitroused383's Avatar
Sounds like your boost reference line is coming off the compressor housing of the turbo correct? If you're referencing the intake manifold this can happen.
Old Sep 11, 2011 | 09:13 PM
SuperZ's Avatar
Yes it's coming off the turbo housing.
Old Sep 12, 2011 | 12:27 AM
SuperZ's Avatar
I'm running wastegate boost source connected to the fitting directly on turbo housing. So I try running a different boost/vacuum source line?
Old Sep 12, 2011 | 01:26 AM
The fastest response to the wastegate will be from the compressor housing, just like you have it. Like cobrakiller said post up some pics of your wastegate placement.
Old Sep 12, 2011 | 07:49 AM
SuperZ's Avatar
I'll get a pic today it seems to be at a good angle though.
What if my banjo bolt on side port of the tial wastegate isn't lined up properly with the flow? Would that restrict flow enough to cause a delay in WG opening ?
Old Sep 12, 2011 | 12:16 PM
IKnowtheFuture's Avatar
i installed a turbo kit on a s2000 and used one of those. it had a like 13 lb spring iirc and it boosted to 25psi and never opened. I bench tested it and it opened at like 27. I put a 10 or 7 psi spring and it opened at 15 psi. I think when I bench tested it i could hear it leaking past the valve guide IIRC.
might want to hook up a regulated compressed air source after you take it out of the car and check it out and turn up the press. til it opens. and also listen for anything out of the ordinary.
Old Sep 12, 2011 | 12:17 PM
FWIW the one i used was a tial MV-R new from the box.
