New C5 Corvette
My question is what is a good build as far as cubes and I am not against resleeving the block and going with some higher cubes if needed. I would then be able to go with some different heads which would help out with the power goals. I would like 800rwhp with the engine rebuild and supercharger build. Does anyone think this is possible.
Do yourself a favor and check out the Dallas Performance Procharger kits, A&A kit, or the ECS kit. All these kits use centrifugal superchargers and for good reason.
The idea is cool, but not if you can't use the power and that idea is offset by the fact that you have a huge heat pump attached to the top of the motor.
You simply won't find anyone in the Corvette world with a PD blower that outruns a centri car. Just search on CorvetteForum for a while. You will see that ECS holds many 1/4 mile records, A&A kit is an awesome bang for the buck and will easily make 800rw, and DallasPerformance is doing amazing things with the Procharger kits.
Jeff at TPE was the leader in KB stuff for the C5 platform and he no longer talks about it or advertises it. He may have even went to TT's for his shop/personal car.
