assembling -20an lines help
thanks
thanks
I also pull the tape off the hose end after a cut before shoving the end in the ferrule. It makes it a bit easier to get it screwed together.
http://coleshotrods.com/?p=201
THis was with lube, but I didn't try backing out the hose a touch as mentioned in here.
And push the hose into the red fitting all the way and then back it out about 1/8" cause it makes it easier to thread in and allows you too get the fitting closer
