Any experience low hp due to dented in dp?
Old Sep 16, 2011 | 02:36 PM
SPRAYED 01's Avatar
Default Any experience low hp due to dented in dp?
My 3.5dp had to be beatened down alittle to fit the sway bar. Its not to bad but im having low hp issues on the dyno.
Comp 80/79 billet wheel,1.32ar 3.5 dp for about 3 feet then 3 inch then cutout.
With a forged 370ci 232/236 cam through a locked converter and 9 inch at 7lbs its only at 490whp and 545ftlbs. The main issue is that it peaks at 5100rpm.
Tuner thinks its may be a restriction in the turbo system.
Old Sep 16, 2011 | 02:39 PM
SPRAYED 01's Avatar
At 11lbs it did 590whp but again around 5100rpm peak.
Old Sep 16, 2011 | 05:26 PM
Nitroused383's Avatar
Post up the dyno sheet, was the cam properly degree'd in?
Old Sep 16, 2011 | 05:38 PM
98Z28CobraKiller's Avatar
Restricted User
undo the Dp and see what happens.
Old Sep 16, 2011 | 06:15 PM
Boo"SS"t's Avatar
I can't see how it could be choking it that bad, unless you're loosing 1/3 or more of the flowpath from that dent. Is your exhaust all the way to the back and thru a muffler or just dump at the bottom?
Old Sep 16, 2011 | 06:42 PM
Sweet_SS's Avatar
I seriously don't think that your DP is an issue. We tested the back pressure on my stock LS1 with a 3 " downpipe (no cut-out) on the TC78 with .96 a/r. on 8 psi and I flow all the way past 6000 rpm. Could be your muffler...it you have one
Old Sep 16, 2011 | 07:14 PM
nastychevelle's Avatar
this.
Old Sep 17, 2011 | 08:18 AM
SPRAYED 01's Avatar
I did not degree the cam, I installed dot to dot. Could this really move the peak hp down 1k rpm?
Old Sep 17, 2011 | 08:29 AM
SPRAYED 01's Avatar
It does have a cutout but its right before the muffler in the 3 inch pipe, not in the 3.5 dp
Old Sep 17, 2011 | 11:12 AM
stevieturbo's Avatar
Post a picture, but IMO it would need to be nearly squashed to make such a difference.
Old Sep 17, 2011 | 11:29 AM
Restricted User
So did you try taking the DP loose yet?
Old Sep 17, 2011 | 12:21 PM
SPRAYED 01's Avatar
Not yet. Its at speed inc right now. They are going to tap in and check back pressure on the dyno.
