Whats with magical #15 = psi?
Old Mar 7, 2004 | 03:47 PM
CAT3's Avatar
Restricted User
Default Whats with magical #15 = psi?
Seems like every thread I read about a SC install its max pullied to 15psi. I dont understand. Can someone shed some light on this? Is the SC thing more for a reliable, round the clock power adder for street/daily use in our LSx community?
Old Mar 7, 2004 | 04:52 PM
99.9percenter's Avatar
Well....15psi is like adding a 200(or bigger) shot. 7psi is like about100hp. In both cases with a supercharger you don't have to refill the No2 bottle (but you still can if you want to). I'm going with 20psi.
Old Mar 7, 2004 | 04:58 PM
CAT3's Avatar
Restricted User
I was thinking maybe its all the poor 4bolt x cyl arrangement and lifting heads. You may have a point about the 15psi = about 200 shot, but I have run a 200shot on stock motor, lots of slightly smaller with much less fuel system/and PITA setups. I would like to see someone pumping more than 20psi with a D1. Just curious, thanks for the comparo.
