Quik Question on 2011 Edelbrock Blown Camaro
I have a customer that is bringing in his 2011 SS that already has a stock Edelbrock blower on his stock motor. We are building him a stout long block and I wanted to pulley it up (smaller blower pulley) how small can I go without slipping the 6 rib and what should be the belt length - please and thanks in advance
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I was merely trying to get an advance notice on what I might come across before the car got here. As an example, we work on Maggie kits all the time so I know what belt and what tensioner changes need to be made when going to a smaller bower drive pulley. We are not as well versed on the Edelbrock stuff. Here is what I got from someone else
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
ok i was busting your *****. I figured with the company name; knowledge and experience would be flowing in your shop. you just dont see big well known shops asking to many questions. i was pointing out that J.R. will be pissed if he knew you were asking questions with obvious answers under his company name. That is all. most 6 rib belts start to slip around 9 psi. yes you will need a shorter belt with a smaller pulley to keep the tensioner in it's sweet spot.
Like no such thing as a stupid question. We don't work on Edelbrock blowers everyday and just wanted the 411 in advance. Sadly Edelbrock could not answer the question. One would think they would know what belt goes with what pulley set up
