Lets talk turbine wheels and "trim,"have some questions.
Hmm that is weird, maybe you just got a blem Turbo? Or here's a thought, do you have a flex pipe in the crossover somewhere? Sometimes they start to fall apart or shrink inside somehow, just throwing out ideas here. Good luck!
I called Joe at comp about which 80mm turbo was used in the ford magazine articles. He said my exact turbo except with a cast wheel. He said my entire issue was the billet comp wheel. I guess on a large cube motor it flows to much and the turbine can't keep up causing massive back pressure. I hope he is right.
Need to update sig lol. Im at 900whp and 9.8 now. Those numbers were with an 80/79 with a cast comp wheel instead of the billet that had the 4:1bp.
The cast had About 2:1 bp.
I since put a ct5 94/88 turbine 88 comp wheel billet. That's about 1.5:1 bp and works well.
#32
Only track times were with the cast, the billet wouldn't even get past 11psi because of the high bp. Didn't think there was much of a point to track it like that.
Comp told me all they did was swap out the billet for the cast. Back when iv was in this a few others said the billet on thatv turbo does not work well.
