which turbo set up should help me
Old Sep 26, 2011 | 07:07 AM
jeremym's Avatar
Default which turbo set up should help me
well i have a 441 LSX twin turbo set up. My cam was speced out for a t3 flange twin 60mm set up.So its real big to bleed off back pressure, but instead i went with a custom t4 flange twin 70mm set up. my 70's are journal bearing and have a .81 a/r housing right now. i was thinking of getting tc76's with ball bearing and a billet wheel with either a .58 or a .68 a/r housing. i want it to spool faster but make good power. i would think going from a 70mm with .81 a/r would be the same as 76mm with a .68 a/r. any help would help. thank you
Old Sep 27, 2011 | 06:20 AM
jeremym's Avatar
anybody?????????????
Old Sep 27, 2011 | 11:56 AM
Ping King's Avatar
I think you should really consider upping to a t4 flange.
Old Sep 27, 2011 | 01:39 PM
Professor_speed's Avatar
my understanding is that it is.
Are you out of compressor? if not why not just run .68s on the 70mm?
Old Sep 28, 2011 | 06:28 AM
jeremym's Avatar
it is a t4 flange.
Old Sep 28, 2011 | 06:31 AM
jeremym's Avatar
i didnt want to choke them down. it made 970rwhp on 15lbs on pump gas. i want to keep around 1000+rwhp driving around on pump gas.
