408ci T76 Setup Question PLEASE HELP!!
First Question
Backpressure. I am adding pictures to this post to show what the exhaust looks like. I was told that this turbo is too small for my setup, which I can agree with but there has to be a happy medium. I have tried several things. Still trying to figure this setup out.
Shifting at 5000rpms which I am thinking, is extremely low. With 9# boost, I managed to pull off the time in the signature. Thinking all this is caused by reversion. I am in 1st gear just under a second. In second gear for a little over a second. Then high gear until almost 1000FT then I hit reverb (over 5k).
Second Question
Exhaust, which relates to the first question. As seen in the picture, will I be better off to run full 3" exhaust in place of where it splits off into two. I have never seen this before on any setup but I am sure the person who built this had some clue of what they were doing.
Also, I am about to put an electric cutout somewhere close to the downpipe but I am needing to know how long the downpipe needs to be, I'd like it as short (free flowing) as possible to help with backpressure. I put a picture down there where I would like it to go. What are your thoughts about this location.
Third Question
I have done a ton of reading under this FI thread. Seems that most people have ran much faster times with less.
Is there any small changes or something that I am missing to help this setup reach its full potential? Will a higher gear help? Something in the range of a 3.08-3.31?I appreciate any and all help provided. I see a bigger turbo in my future but I want to reach full potential with what I have while I am saving up!
Hope this helps!
https://ls1tech.com/forums/forced-in...04ci-76mm.html
Also, was asking about rear gears. From what I have seen, a 3.73 is not very common in turbo setups. Do I need to run a higher gear?
Here is a picture of the exhaust off the car, would this exhaust flow better if it were one 3" pipe all the way through? Not sure about splitting into two smaller pipes.
It is the bottleneck, and unless you open the bottleneck up your other 'fixes' will be useless. Sorry for being the bearer of bad news.
But that exhaust going into two and back into one could be improved upon greatly by stepping it up to 4" single where it goes from one to two and run it 4" out the back.
