Incon installers....help
Old Mar 8, 2004 | 02:29 PM
cablebandit's Avatar
Default Incon installers....help
I decided to remove the plug on the drivers side of the block today...the 28mm--1.25 brass plug. Anyway, it takes a hex bit to get it out...anyone know what size? I suspect it is 17-18mm but not sure.
Old Mar 8, 2004 | 02:32 PM
y2khawk's Avatar
17MM
I used a metric bolt w/ a 17mm head, and welded another nut onto it to put a socket on.
But you could always use two nuts tightened against eachother.
Old Mar 8, 2004 | 02:57 PM
tried the 2 nuts deal and snapped the bolt I hope the 17mm hex can take the pressure of my massive 11" pythons If the frame shop would hurry up with my turd I could bolt this bitch in. harlan you think I could get 650 dynojet with stock incon and stock heads/cam?
Old Mar 8, 2004 | 03:28 PM
y2khawk's Avatar
I've already seen 630 with that setup but without something more than a single 340 we didn't wanna press our luck.
If you've got the fueling set, you should be there
Old Mar 8, 2004 | 05:49 PM
I have 2 intank 340 pumps AND a BAP.....shouldn't need the Boost-a-pump tho. still got my 42# injectors but will switch over to the mototron 60# after I accumulate some more cash. Thunder Racing suckered me...gave me a great price on a suspension setup and awesome customer service......now I am broke again
