PT76 Stock bottom end LS1 717/720 12.5lbs
UNDER PRESSURE MOD
Damn impressive, even if it was only for a one time max effort pull.
I think I'm overboosted at the moment as I am hitting 200kpa at 6900. I am also out of injector as well, but it's way rich above 4000rpm, sub 10.5:1.
What rear gears are you running? I have 3.73s in a factory 10-bolt and I'm considering going back to 3.42s to help a little in the traction department in first and second.
UNDER PRESSURE MOD
Nitroused383 isn't an idiot, he knows it's just a dyno queen number and not a real world number. Fact is, you can push a motor harder on a dyno since it doesn't see nearly the same load as on the street or track. It's simply a dyno number, nothing more, nothing less.
Ya I ran 10.6 @ 133 with easy shifts, when I powershift it picks up 3-4 mph. I ran with a completely full tank The only pass I ran out before getting kicked off the track was at 9.5-10 afr with 3-5 degrees of timing lol! We all know how easy turbo's and 6 speeds are haha. I'd like to go back but I've been kicked 2 times in a row so they're on to me. My car isn't setup for drag though I have stock zr1's up front, stock LCA's, stock slp lowered bilstein springs / shocks and just 26" slicks. They had other cars at the event. 2002 TA, headers, LS6 intake, 230/234 cam and 243s did 405 through a 6 speed. My friends 01 camaro forged 370 prc 227 ($$$), 11.7:1, 238/250 cam, ported fast 90, 1 3/4 headers, 12 bolt and a 6 speed did 410 rwhp n/a and 550 / 680 on a 200 shot.
The impala in the video is a 470 bbc with twin 70mm turbos on 22 lbs of boost with a 75 shot of nitrous and q16 made 890 rwhp / and lots of toque.
http://www.youtube.com/watch?v=WG9MRgbYXBw
2800' DA
http://www.youtube.com/watch?v=2DeEFNArqW8
2800' DA
Im supprised your car even runs with 3-5 degrees of timing. Lowest ive ever seen was 8 and it ran like real ****.
congrats on the times.
Thanks alot, it really makes me want to go back as I know I left a lot on the table. Ya I didn't realize the timing was so low until after I already got booted. It didn't feel like it was running right but I had my best launch of the night so I stayed in it. I think our track is open maybe 1 or 2 more fridays, I'd really like to go but they told me I'm done until I get a cage
#33
I know the feeling of leaving it on the table and not hanging it all out.
I know you and alchemist have 6 spds, but the comment about the 26" tires and 3.50ish gears holds true for me too. My car really woke up with the 3.55's and 26" hoosiers. Even with my heavy *** chrome C6 ZO6 wheels(18" 305/35/18) it is plenty peppy.
#37
Here is the graph with 15lbs of boost, you can see where the tune pulled 10 degrees of timing, dropped almost 100hp. If I had 10 more degrees of timing it either would have A. Blown the hell up or B. Made over 800 rwhp, considering it made 717 through the dual dual with 11.5 lbs and the 15lb pull was with open cutout. Fuel system was maxed out as you can see in my log file. 3.5 degree of timing lol but tapered up to 5.5 by 6000 rpm.
#39
1 Post
At least the track guy was "nice" about telling you, no more runs. Where I came from, they would throw you off the track property, no if-and-or buts about it. Nice numbers for such a "low" RPM.
