Turbo cam ?
Kurt
Kurt
Kurt
The specific reason is your turbo...
I would be more worried about the hot side of that turbo than I would be the cam. That turbo is smaller than what I personally run on my little 3.0 liter V6! That is why you will make boost really fast, which as stated is fun, but can be dangerous to the engine at the same time. The cam has some to do with that, but nowhere near as much as that small A/R ratio coupled with a small turbine wheel. If you can, I would try to get the biggest A/R ratio turbine housing as you can for that turbo, Or, just switch turbo's all together to one that will flow more exhaust. If neither of those is an option, then just rock it and take baby steps in the tuning.
Oh, and 9.5:1 compression is great for a turbo engine.
Oh, and with that turbo, you probably will not be turning that high of RPM's coupled with boost. Therefore your current manifold will do fine as was already stated.
