t70, 4.8l 87 IROC. couple questions
im in the process of collecting parts for my build. im building my 87 IROC with a turbo 4.8l. im planning on using a t70 turbo around 8-9lbs of boost. my questions are....
what size injectors should be good?
what size intercooler?
would i need a 3bar maf?
would a ls6 cam be good to use?
ive done a build like this before on a 87 rx7 with a t70 5.3l but it never ran well.\
thanx in advance
thanx in advance
I was thinkin of running a full exhaust but also running a cutout and have it come out either the rear of the passenger side fender or just dump it.
Ok so I won't need a 3 bar map?
I'm just wondering on what size intercooler? I was thinking a 24x12x3. But dunno if that'll be too much intercooler. My rx7 was on a SD tune and ill mostly likely tune this on a SD tune too. Its not goin to be a daily driver or a race car, pretty much its just goin to be something fun that'll alsolook good.
Always love the WOW factor.
ok just wanted to make sure. what size would i need if i want to run 8lbs?
sorry on my rx7 i just ran 55lbs injectors, 8lbs wastegate and just a 255lph fuel pump and it never ran lean. although i was never get into full boost before something would pop off. lol
Size intercooler? The one you mentioned will work well. Boost referenced fuel pressure regulator has a nipple on it to attach to a vacuum source, it will rise 1:1 with boost. My intercooler core measures 24x6x3.5 , that's just the core, the end tanks make it bigger. Here's the one I have, I didn't have to cut the car at all, just move the lower hood latch mount.
http://www.treadstoneperformance.com...es+Intercooler
So I was talkin to some of my buddies last night about my build and they said that 60lb injectors are way to big. They said I should be good with 42lb. My buddy got out some horsepower calculator and started talkin all sorts of math non-sense and I just kept ignoring him (I ignore him cause all he does is read forums and puts lights on his car)
LS1Tech Sponsor
Not to mention, 60's tend to cost about the same as 42's, and will leave some room to grow if you decide to make more power or go E85 in the future
