doin a really basic turbo set up...advice appreciated
Old Oct 6, 2011 | 03:48 PM
nevrlift13's Avatar
Default doin a really basic turbo set up...advice appreciated
lookin to do a real basic set up-already got a TC78 gonna do truck manifolds with crossover racetronix pump custom ground cam with golds "317s" 60lbers (do i need bigger) cx fmic tial 46mm WG and not sure on BOV...lookin to push around 10 psi or less...any advice i can get is appreciated, have had two nitrous cars previous to this so boost is a whole new ballgame to me...thanks :hail
Old Oct 6, 2011 | 10:42 PM
Sweet_SS's Avatar
I've always used Tial for my BOV and wastegate. But on this car, I opted for the Precision 39mm wastegate. Also, I am on a stock motor using 60lbers (8psi). The best thing you can do here is switch to the 2bar map sensor. Go speed density and bypass the MAF.
Old Oct 6, 2011 | 11:47 PM
skinnies's Avatar
Precision 46mm wg is a lot nicer than the tial IMO, also race part solutions has a 50mm bov for $100 that we've had really good luck with on cars.
Old Oct 7, 2011 | 10:46 AM
nevrlift13's Avatar
thanks for the input, new to all this boost stuff...ill check out precision for sure...100 only for the bov WOW gettin of easy on that one...
anyone know the dims i need on the FMIC im searchin and not seeing it..also if anyone knows a place that has prefabbed crossover pipe and fmic piping?
Old Oct 8, 2011 | 08:18 AM
nevrlift13's Avatar
lookin at forced inductions.com last night seems to have almost everything i need
anymore input is appreciated...really had more quesitons abt fueling it...read some of the stickys and theyre saying a racetronix isnt gonna be enuff for 8-10 psi?
Old Oct 8, 2011 | 01:49 PM
Fondle's Avatar
i went with the precision 46mm wastegate, very nice unit and comes with ever spring you need to run 1-25lbs of boost
also i used the 50mm RPS BOV from modular turbo, a sponsor on tech, Almost identical to the tial unit but about 40% of the cost. Looks great and came with stainless and aluminum flanges. Very nice unit and sounds very good too
I am running 36lb injectors on 6-7lbs, so i think 60s will be plenty fine for 10lbs
Old Oct 8, 2011 | 04:44 PM
nevrlift13's Avatar
whos injectors u runnin? i was gonna go RC since theyre local but open to suggestions
