APS TT C6 w/ upgrades
Old Oct 14, 2011 | 12:22 PM
Larry @ AMS's Avatar
Default APS TT C6 w/ upgrades
This 2007 C6 Z51 came to us with a stock LS2 and an APS kit w/ custom 3“ DP's and 3" exhaust with no mufflers, fuel system upgrades with surge tank ( unknown ), AEM single nozzle meth kit, AEM True Boost, Z06 body kit, Z06 wheels and a few other odds and ends, but was in need of some TLC.
The customer purchased the car used and has had many issues since with turbo failures, exhaust leaks, clutch issues and it ran poorly. We got digging into the car and found many, many issues that needed to be resolved and then some as we got deeper into the project:
• The fuel system had standard rubber hose on push lock fitting which was all brittle, burned or ready to crack.
• We found that an induction had come off on the driver’s side and therefore sucked lots of dirt and debris through the turbo which ruined it, packed the drivers intercoolers and unfortunately the motor saw some of this as well. The charge pipes were rubbed through on both sides from improper installation and tire contact.
• There were numerous burned wires and vac. lines.
• 1 broken 02 sensor
• Pass. side downpipe was leaking badly due to missing hardware
• Exhaust poorly adjusted and out of hangers
• Meth system installed incorrectly and therefore not functioning. Washer solvent was used
• The wiring for the meth, true boost & fuel system were a disaster.
• There was low impedance injectors with resistor boxes installed which 1 was broken. The injector harness was all hacked up as well.
• The torque tube input shaft was found damaged upon removal.
• 2 bolts missing from bell housing
• Radiator cradle only in by 1 of the 4 bolts
• Crank pulley wobbling
• Diff and trans seeping and covered in dirt/grime
• Air horns crammed in inner bumper 
I think the above notes cover most of the issues…
The route of attack was to perform a leak down and compression test which surprisingly was OK. We then received the go ahead to move forward with the project. The list below is all the new items, repairs, upgrades we performed:
• PRC .650 kit (retained stock cam shaft)
• Comp pushrods
• SLP / PB crank pulley w/ ARP bolt
• GM input shaft, GM pilot bearing,
• DSS 3” driveshaft and couple kit
• McLeod RXT w/ steel flywheel
• GM slave
• AMS remote bleed line
• APS manifolds smoothed and ceramic coated
• APS Z06 intercoolers
• PTE Billet upgrade HP5830’s w/ revised intake tubing
• K&N filters RE-0930’s
• Flush and clean all inlet/charge pipes and intake manifold of dirt, grime and debris
• Readjusted and repair charge pipes. Install new SS couplers in the event of tire contact
• Upgrade AEM to dual nozzle and fab MAF delete pipe which houses nozzles and IAT
• GM 02 sensors with new extensions
• FIC 1000 CC injectors, repaired wiring harness with new clips and removed resistor boxes
• MSD wires
• NGK TR7 plugs
• Revised all fuel lines, fittings and relocated regulator
• Revised all vacuum lines
• Relocated breather catch can
• Designed a relay and fuse distribution block
• Rewired fuel system, meth, true boost
• AEM wideband with custom mounting in center vents w/ meth indicator LED and refinished center console
• M1 50/50 mix for methanol
• Diff and trans fluids serviced
• OEM horns
• Repaired radiator cradle and secured properly
• Lots of heat insulating to protect wiring, fuel lines and vacuum lines.
• 2 bar MAP and AMS Tune via HP Tuners
• Detailed
We wanted to stay safe with the car seeing that is had been thru some hard times, so boost was kept at a safe 10 psi. 93 octane w/ Meth
Results are on our Mustang Dyno are as follows (approx. 10% lower than a Dyno Jet)
584 rwhp / 537 rwtq
The turbo’s come on very fast and due to the car being on plain street tires its worthless 1st-3rd gear and depending on the road only gets decent traction in 4th. The customer picked up the car Friday 9/30 and was very pleased with it driving like stock and getting almost 30mpg on the ride home!
The car went to the track just 2 days later with the same street tires and little seat time, but he still managed an 11.2@133. I know he is working on getting some drag radials to get back out before the season is up to see how it will really run. I think the car is good for mid-lower 10’s at 135+.
Here are some pics of the project :
Old Oct 14, 2011 | 12:30 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Great job, turned out awesome.
Always good to see track times (MPH) posted with the dyno sheets, keeps things real
Old Oct 14, 2011 | 12:38 PM
tomz28's Avatar
i hate people that hack **** up. Looks good guys,great work
Old Oct 14, 2011 | 12:40 PM
2000RATA's Avatar
Nicely done. You saved the car from a former hack! And that is a corvette. I can only imagine what some of these budget builds look like on some of the camaro and TA's here that never do build threads.
Old Oct 14, 2011 | 12:55 PM
cracker's Avatar
Looks similar to the LG Fuel System...
http://www.lgmotorsports.com/Forced-...on-Fuel-System
Old Oct 14, 2011 | 01:30 PM
Louis's Avatar
Larry, did that car come out of Colorado?
Thats one of the poorest Corvettes Ive seen, much less a TT one with that much invested in it!
Way to restore it and keep it alive!
Wade- its similar, but that surge tank in the yellow car is pressurized to rail pressure, ours is not. Its an odd setup, but it works. I called him out on Corvetteforum when it was produced.
Old Oct 14, 2011 | 01:50 PM
cracker's Avatar
I noticed that. That's why I said it "looks" similar.
Not to get off topic but how is Ryan Sprehe? I haven't talked to him in forever.
-W
Old Oct 14, 2011 | 02:22 PM
similar as in a surge tank yes, but far different in design as Louis mentions and you later cleared up
yes I believe it did come out of Colorado. We are glad we were able to turn it around for the customer and make it something enjoyable to own.
This surge tank works, but not the way we would want it to due to it's design as mentioned.
thanks Louis
Old Oct 14, 2011 | 10:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Wow! That guy must of lived down a dirt road in the boonies every day. You guys did a great job bringing it back to life!
Old Oct 14, 2011 | 11:56 PM
bbs350z's Avatar
Its amazing how somebody could take such a car as that, stick that much money into it and treat it like ****. That or the previous owner had no idea of the hackjob that was done. Hence why I do my own work because I'm a picky bitch
Old Oct 15, 2011 | 10:59 AM
thanks Mike .. I to love to see track times.
thanks
yeh it's sad to see what some people can do to a nice car and then a customer like ours buying something not really knowing what he is in for
yeh..it sure took in some debris
thanks for the compliments
yeh.. it's sad too when someone has a car done and has no idea themselves. I do not know who owned the car prior other then I believe it came from Colorado as mentioned, but can only hope the previous owner was unaware of the mess and did not intentionally burn the current owner.
Old Oct 15, 2011 | 04:06 PM
venom ws7's Avatar
Great work/numbers and looking car.
Congrats to the owner I hope he can use it for street/drag use not off road
Old Oct 17, 2011 | 08:40 AM
thanks
Old Oct 18, 2011 | 03:41 PM
http://youtu.be/4EvInkqgBao
Old Oct 19, 2011 | 03:57 PM
GNXClone's Avatar
Question
Nice! I hope you don't mind a few questions...
Where did you source the insulation?
I need to do the same very badly. My APS equipped GTO is losing the plastic wiring loom due to it becoming very brittle and crumbling apart. I'm sure it's from the added heat of the turbo system.
I'm tempted wrap it first with stick-on aluminum tape for A/C and heating vents, then cover that with high-temp electrical tape, if such a thing exists.
If there's a better alternative, and I'm sure there is, I'd like to hear about it.
I have the same injectors ready to go on the car. I'm currently running the 2.5 BAR OS from HP Tuners on the E40, speed density, with 60# Siemens/Deka injectors.
If you don't mind sharing, how did you scale for these injectors? I have read of at least a couple different ways to handle large injectors on Gen-IV engines. I haven't decided which to try first. Possibly the AFR scaling since that's the least intrusive. If that doesn't work, then restore the AFR table and totally rescale of all of the other tables by 50%.
Thanks!
Old Oct 21, 2011 | 11:45 AM
WeakSauce6's Avatar
Very nice.
Old Oct 21, 2011 | 01:44 PM
02blackbeauty19's Avatar
GNXClone: I don't know where AMS sourced their heat resistant wire protection, but if you go to google cabletiesandmore and go to their store, they have tons of it in spools. It gets kind of expensive, though.
Old Oct 24, 2011 | 03:19 PM
GNXClone's Avatar
Thanks! I ended up getting this:
Thermo-Tec's new Express Sleeves are just exactly what our customers have been looking for. The new easy to use sleeving is a combination of a high temperature insulation material to a highly reflective mylar foil with a Velcro closure. The sleeving is designed to provide maximum protection for wires, hoses, and cables from the very damaging effect of radiant heat with an easy application. Simply pull apart the material, wrap around the wire, and re-close the sleeving. Express Sleeves reflect over 90% of radiant heat, is fireproof and fire resistant, and just looks good. Express Sleeves come in 1 1/2" diameter in 3', 12', and 50' lengths.
Old Oct 25, 2011 | 09:26 AM
Thanks!
I'm sorry for the late reply, but I was at the TX Mile and did not have web access other then my phone and it did not work the best.
to be honest I'm not sure where our engineering dept sources the heat insulation we use in our turbo kits which we pull and use on other builds as needed
tune wise our tuners our both out and I can't ask them at the moment. I do know it took some time to get things in order
sorry I could not be much of a help with these particular questions, but it looks like you got the insulation handled
Originally Posted by WeakSauce6
Very nice.
thanks!
