5.3l turbo build
I think a lot will be determined by your method of producing boost. Along with the fuel and CR you use. The tune quality goes without saying.
I'm using a Procharger, but it's not ideal if you are looking for the highest wheel hp out of a power limited stock bottom end. At the 700 rwhp airflow level and 20 psi of boost, the Procharger will consume about 110 crank hp. By comparison, a turbo is nearly free (if we ignore inefficiencies created by having a blockage in the exhaust stream.
This means 600 rwhp on a Procharged setup will be stressing the engine like say 680 rwhp if you were using a turbocharger. So, if there is some 'limit' at which parts start to let go, you will reach it earlier with supercharger than you will with a turbocharger.
Hence I'm a bit worried about trying to get 700 rwhp out of the motor with an F1A Procharger. I'm just hoping if I go with a low CR and tune very carefully with the E85, it will have a chance.
