Fan Combinations for FI Cars
Old 10-21-2011, 08:01 PM
Fastbird93's Avatar
Default Fan Combinations for FI Cars
Ok, I know it's an LT1 car, but the principle is the same. Stroker, turbo, decent HP numbers, yadda yadda yadda. Running in a stock radiator, stock location w/ a/c condenser, stock shroud with recommended cheapy low profile fans that are used in kits with vertical radiator turbo kits. Intercooler is horizontally mounted in front of the radiator crossmember, so there's very little restriction in the airflow going up to the radiator, and certainly less than if I had the radiator standing upright.
Car was running at about 210-220 on a 55-60* day today. Too warm for my taste.
So I was wondering, how much do you think it would help if I were to install a pair of decent pusher fans on the front of the A/C condenser for a pusher puller four fan combo for airflow? Crazy? Bad idea? Good idea? Other ideas?
Old 10-21-2011, 08:31 PM
Cam72aro's Avatar
Bad idea. Get a really good shrouded set of pullers. The pushers will cause a restriction for the pullers, or vice versa.
Old 10-21-2011, 08:41 PM
Fastbird93's Avatar
Problem is that I've got no room for a big set of pullers. I'm going to look into better pullers that are more stockish in CFM's, but I can barely fit in the ones that are in there now and they're about the thinnest I could find.
Old 10-22-2011, 08:27 AM
Cam72aro's Avatar
can you stand the radiator up? I run a dual spal puller setup with the radiator stode up.
Old 10-22-2011, 11:44 AM
So.jerZ-28's Avatar
I had 2 pullers w/ 1 pusher when radiator/condensor were together like factory has it, always ran a lil warm for my taste too.
My Fix:
Cut front of rad support, moved condensor down & foward 2"+ installed pusher on radiator between the rad & condensor. temps dropped 15-20+ degrees.
(you have to bend a/c hard line straight & small bend at end to make line longer to reach)
Old 10-22-2011, 11:56 AM
Fastbird93's Avatar
Oh, I could stand the radiator/condensor up, but I won't. I'm keeping it looking as factory as possible. I've talked to a couple of other guys who've had success with a pusher on the front and a puller on the back, so I think I'll give it a go.
Old 10-22-2011, 03:46 PM
Cam72aro's Avatar
Hey, you could also make the car run cooler, but it seems you won't. Good luck with the pusher puller setup. When it doesn't work and you want it to run cool tell us how standing up the radiator works. Wanna keep it looking factory as possible? Take the turbo off it then. I don't mean to sound like a dick, but hate when people ask for advice and then don't like the answers they hear.
Old 10-22-2011, 07:56 PM
Fastbird93's Avatar
Who didn't like the answers? Your advice was sound, I never discounted it, only said it wasn't an option for me. Sounds like you didn't like that I'm not taking YOUR advice. What works for you doesn't work for me, plain and simple. You don't have to be a dick because I don't like your particular advice. Sorry to sound like a dick.
Old 10-22-2011, 08:15 PM
Cam72aro's Avatar
Could car less if you take my advice. Just hate to see you waste your time on something I already know about. I have spent a bunch of money figuring it out the hard way. I did the stock radiator with pushers, pullers, split pusher pullers and it didn't do what I wanted. I ultimately went with a bigger radiator and a good puller setup. The stock core is only a single row and doesn't have a whole lot of capacity. The more water you can put in the system the better.
Old 10-22-2011, 08:43 PM
lt1badbird's Avatar
big front mount single turbo car here. nice thick aluminum aftermarket radiator leaned wayy forward. summit racing shrouded dual pullers. stock waterpump. car will idle mid 190's all day
Old 10-23-2011, 08:21 AM
evo462's Avatar
Here are the pushers I bought. My car isn't running yet, but many others have used these to push through a condenser and radiator and had no cooling issues.
http://www.summitracing.com/parts/DER-16925/
Old 10-23-2011, 09:32 AM
Pocket's Avatar
210-220* is normal for a LT1, they run pretty hot
If that bothers you run a lower thermostat
BTW, its a good idea to put some sort of fan on the intercooler as well when its not against the radiator. When its against it, the rad fans will draw through it
Old 10-23-2011, 10:43 AM
MIGHTYMOUSE's Avatar
what thermostat? what low/high fan settings?
i run a lt1 radiator and lt1 fans in my car, works great
i dont have an a/c condensor in front of it but i do have a tranny cooler
Old 10-23-2011, 11:37 AM
Ryans99ls1's Avatar
Thats what im using. Koolrayz and Tally have used them without a problem too
Old 10-23-2011, 02:18 PM
Fastbird93's Avatar
It's a Hypertech 160* thermostat, Meziere EWP, stock radiator, non-stock pullers mounted in the stock shroud. Fans are set to come on a 180* and go off at 170* IIRC.....I'd have to pull the tune off the XFI and look at it.
I am running a 10" puller on top of the intercooler also.
210-220 is normal for a stockish LT1. I haven't run over 190 for a long time until I crowded up the engine bay.
Old 10-23-2011, 05:23 PM
Cam72aro's Avatar
a 160 t stat can actually make a car run hot. It hard for an engine to cool to 160 so the t stat is open all the time. Also, its easy to keep a car cool without a condenser. Keeping the ac is the tricky part.
Quick Reply: Fan Combinations for FI Cars
