A4 with STS build
Old Oct 24, 2011 | 08:53 PM
LT1_King's Avatar
Default A4 with STS build
hey guys its been a long while since i been on here.... i sold my 94 LT1 and not too long ago bought a 2002 A4 Z28... the car has 111k miles on it and shorty headers and 3.73s out back.... i hve an sts used turbo kit with intercooler that i am gonna put on.. i did a search but i'm not really finding what i'm looking for i keep getting cars that are forged and not stock bottom end.... my questions are what could i expect from the car on 8 lbs of boost if i have no stall on the car on a drag radial... the car is my DD driver and sees the track quite a bit... the car did a 13.50@ 103.9 and 2.0 60 ft... the d/a here sucks it was almost at 5000 thanks in advance guys
Old Oct 24, 2011 | 10:16 PM
LT1_King's Avatar
No one?? Come on guys I just really wanna know what I can expect from this??
Old Oct 25, 2011 | 08:23 AM
2002kirk's Avatar
My guess would be about 12.5 if you hook but for a DD I wouldn't take it to the tack without the proper provisions like a better rear and perhaps a stall but I'm a worry wart.
Old Oct 25, 2011 | 10:11 AM
jak2908's Avatar
im doing the same thing w/o the intercooler and going to be on 5 psi until i get it tuned...i should have it done by the end of this week, ill keep you posted
Old Oct 25, 2011 | 10:48 AM
JAX04's Avatar
i would NOT be in ANY boost without a tune...
Old Oct 25, 2011 | 11:04 AM
Sweet_SS's Avatar
I am with JAX here, do not boost without a tune.
Old Oct 25, 2011 | 12:59 PM
jak2908's Avatar
can i send the ecu to anyone and have them do it? or do i have to have it dynoed and such
Old Oct 25, 2011 | 02:35 PM
Sweet_SS's Avatar
http://www.tunedbyfrost.com/
Old Oct 25, 2011 | 03:13 PM
jak2908's Avatar
i take it that he is pretty reputable? i dont know any info about the turbo i have...it was in the sts kit i bought used..
Old Oct 25, 2011 | 03:16 PM
jak2908's Avatar
whats the worst that could happen if i dont get it tuned right away?
Old Oct 25, 2011 | 04:31 PM
c0ncEpT's Avatar
The motor blows up...
You can drive it around for a short amount of time before you get it tuned but you need to keep it out of boost.
Without a tune once it gets into boost it will go lean/be over timed and it will detonate.
Old Oct 25, 2011 | 04:36 PM
jak2908's Avatar
gotchya....i could go with frosty or i have a somewhat local tuner and he also does dyno pulls for 400 bucks..
Old Oct 25, 2011 | 04:45 PM
LT1_King's Avatar
so about a full second increase? how much better with a stall converter? and say up the boost to about 10lbs if it wasn't my DD?
Old Oct 26, 2011 | 12:42 AM
chance575's Avatar
Drive it with the intake hose disconnected, that way you will see no boost.
Old Oct 26, 2011 | 12:55 AM
RoidedSS's Avatar
the more boost, the more weak links you will find......(rearend and trans seem to be the weaker links in the f-body drivetrain)
Old Oct 26, 2011 | 01:03 AM
lemons12's Avatar
I personally would copy "Zombies" setup as close as possible.. You can search for a 100% detailed setup from him.
Converter is a must for even a stock auto, they are dogs other wise.
Old Oct 1, 2012 | 10:26 PM
HRHohio's Avatar
Bringing this back up for you. Any updates?
