Testing Eboost2 ??
Old Nov 5, 2011 | 06:37 PM
pwrtrip75's Avatar
Default Testing Eboost2 ??
This boost controller I got, the gauge end, display, programming.. all work fine. Ive hooked it up both the different ways that the instructions say... single turbo to external wastegate... la la la. The thing does nothing.
Stays at gate pressure no matter what I do.
Is there a way to test the solenoid? I have no way of knowing if it works. Cant really hang my head under the hood while making boost.
Old Nov 5, 2011 | 07:04 PM
js2fst's Avatar
Call Marty at Turbosmart
Old Nov 5, 2011 | 07:06 PM
pwrtrip75's Avatar
Its probably too late right now.. and tomorrow is sunday
Old Nov 5, 2011 | 07:48 PM
MUSTANGBRKR02's Avatar
You do know that the reading that you set is not psi but a percent of the spring. So setting it to lets say 12 isn't 12psi.
Old Nov 5, 2011 | 07:53 PM
pwrtrip75's Avatar
Yes, I know this. I have it set up for 3 settings, low, mid, high.. it stays right at my spring pressure of 6psi.
Old Nov 5, 2011 | 08:45 PM
tomz28's Avatar
what is GP set at? tell me what you have tired
Old Nov 5, 2011 | 09:02 PM
It's so hard to troubleshoot this thing without looking at it.
Old Nov 5, 2011 | 09:07 PM
pwrtrip75's Avatar
I will go out tomorrow and look.
Old Nov 6, 2011 | 06:14 AM
stevieturbo's Avatar
Ensure the overboost obS trip is set high enough that you can actually make boost before it shuts down to protect.
Old Nov 6, 2011 | 09:19 AM
tomz28's Avatar
^^^^^^^thats a good point to. it is really hard to help without looking at it lol
Old Nov 7, 2011 | 04:18 AM
VUSS383's Avatar
Agree exact setting are need to help out ! Also have a look & report back with the pressure displayed @ key on & also at idle !
Old Nov 7, 2011 | 11:52 PM
skinnies's Avatar
I'd think that noid should be just power/ground, you can test it to make sure it cycles at least. I've never used the eboost2, but should be the same as other noids out there.
Old Nov 8, 2011 | 03:53 AM
10sec_rx7's Avatar
7 Second Club
the soloniod will click when you first power it up,
