Supercharged, or not?
Old Nov 5, 2011 | 11:02 PM
gMAG's Avatar
Default Supercharged, or not?
I want to keep the present cam, TR224, & mildly ported stock heads. Rod bolts are ARP's.
Will a supercharger match up with this cam, and if so, which do you recommend?
Would a turbo be a safer bet?
I'm not sure that the cost of supercharging will be worth it when played against any HP increase.
Old Nov 6, 2011 | 08:38 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
You may like the cam, but it's not ideal for forced induction, especially if it's on a 112lsa. The investment in going to forced induction is substantial, and trying to base you decision based on the current camshaft is backwards. It's like buying a new home based on what wallpaper is in the guest bathroom.
My advice is figure out which type of forced induction you really want, then swap the camshaft to match that setup.
Old Nov 6, 2011 | 04:50 PM
gMAG's Avatar
I should have mentioned that the cam is a 114.
Does this mean that if one wants a blower, that the cam must be a blower-designed cam?
Old Nov 6, 2011 | 05:19 PM
UNDER PRESSURE MOD
No, it doesn't mean it has to be, but to design a FI setup around a cam is kind of backwards. Will the TR224 work with a blower, sure, but other cams may work considerably better, that's all, and in the scope of things, a cam change is not a big deal.
Old Nov 6, 2011 | 06:43 PM
gMAG's Avatar
Thanks, I appreciate your advice.
Old Nov 6, 2011 | 07:30 PM
Cam72aro's Avatar
Look at the turbo thread From Tinkrd. He has a turbo without a turbo cam and made some serious numbers. I think there are some good blower or turbo cams out there, but there are also a lot of hype that makes you think you have to have that cam to make power. The cam you already have is somewhat small would probably work pretty well. I would figure out what you want to do blower wise and leave the cam in there. Then maybe later on switch to a FI cam.
Old Nov 8, 2011 | 08:58 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
8 psi with your cam and ported heads with a ProCharger could get you an additional 160 to 200 rwhp. The TR224 cam responds very well with a ProCharger, if you do go with a ProCharger I'd leave your cam in there. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 8, 2011 | 02:08 PM
UNDER PRESSURE MOD
Good call Bob. I wasn't trying to discourage him from keeping the TR224, but rather be open to options. Glad to hear it works well for his future plans.
Old Nov 8, 2011 | 08:01 PM
gMAG's Avatar
Bob,
The LSA on this cam is 114. From what I know (not too much!) about superchargers, the LSA should be less in order to obtain the greatest effect from a blower. So, in my case, would a 112 or less have been a better choice as opposed to the 114?
Thanks, Glenn
Old Nov 9, 2011 | 09:31 PM
Cam72aro's Avatar
You want a wider lsa, which means a higher number. Your 114 will work great for a blower.
Old Nov 10, 2011 | 06:27 AM
LS1Tech Sponsor
Bob,
Thanks, Glenn
Basically, it is the other way around as the post above this states. Bob
__________________
Old Nov 10, 2011 | 07:46 AM
allout06's Avatar
FWIW, my cam is a very non-boost friendly cam. 231/234 .648/.598 111lsa. I didn't even have FI in mind when I did my cam swap, then came across a good deal on a D1 so it switched my path completely (for the better I might add.) but my car made 383 with cam only then the blower at ~5.5psi with a FMIC it made 571. So that's 188more horse. Not bad for stock 853's, and my cam.
Old Nov 10, 2011 | 12:39 PM
Cam72aro's Avatar
I would say its pretty good. 571 on 5.5psi is pretty awesome
Old Nov 10, 2011 | 03:50 PM
allout06's Avatar
thanks i was surprised! Makes me wonder what i would of made with a set of a decent set of heads and a blower cam and at 8-9psi.
Old Nov 10, 2011 | 06:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
Wide lsa is some kind of Internet talk. All our high hp pro charged cars have tight lsa's.
Old Nov 10, 2011 | 07:14 PM
allout06's Avatar
wonder why everyone pops boners over the wide lsa's then
Old Nov 11, 2011 | 03:22 AM
RT.66's Avatar
Interesting, I wonder what kind of power I can make with my set up?
Old Nov 11, 2011 | 03:51 PM
gMAG's Avatar
Don,
Are you saying that lower LSA is more advantageous (ie 110-112), or the reverse?
At what LSA does blower power become disadvantageous?
I'm still trying to get my car to you for a tune...after a low oil pressure issue is solved.
Thanks, Glenn
Old Nov 11, 2011 | 07:35 PM
Cam72aro's Avatar
Ok, higher number. Is that better, lol? 114 is better than a 106 for a blower car.
Old Nov 11, 2011 | 10:47 PM
allout06's Avatar
so anything between 110-115 will work fine with a blower er? or 12-115...111-117. where does the line get drawn?
