HELP with 8 Rib Procharger Pinning Kit
the fixture slides over the end of the crank with the ATI balancer off. there is a hole on the side of the fixture where you put the supplied drill bit guide. insert the guide, and drill away. keep it lubed, it takes awhile to drill through. the crank is very hard. once its drilled, tap in the pin wuth a hammer just far enough so ur ati balancer that is notched will slide over the pin. Just like it had a keyway make sense?
Jason
http://shop.brutespeed.com/ATI-3GKMM...-3GKMM-004.htm
.i however wonder if its best to put just one...or if i should put two pins in....i guess one will be fine and if it shears off ill replace it and add another. ill keep it lubed for sure...thanks alot. the rear is dropped now and im installing the hotwire kit and racetronix which is top notch stuff...i added the extra option for the booster in case i make too much hp. right now i am looking for that damn adapter to attatch the -4an valve to the fuel sending unit for my pillar mounted fuel pressure gauge. i need a -4an to 1/8. its a glowsport fuel pressure gauge 0-100 psi. i have to say i thought i was going cheap on gauges but they have turned out to be very good products and im not just saying that. i however did go with the propsport evo wideband gauge. if you guys have any other information about what to do and not to do let me know. i am doing the install myself not only because i want to save money....but because i want the knowledge and reassurance that it was done as good as it could be. so far im almost into the 10k dollar range with my FI needs. and rear end and trans and forging is still left to boot. haha. i love it though. to hell with smack.
Position doesnt matter, one or two is up to you. Personal preference, but Id suggest ditching the pin they send and cutting the shaft off a 1/4 drill bit. Hardened tool steel is stronger than the stuff they send
when i did my pump, i did the trap door way. i wasnt about to drop the damn tank lol. And if i need an upgrade later, ill just do a lnnies dual fuel pump kit, or make my own.
Are you forging ur motor now? You have a D1 correct? if you plan on going over 600rwhp, id go ahead and add a boost-a-pump, youll probably need it. what size injectors did ya go with go? HP goals? good luck! and make a build thread!
id def do a FMIC too!!
Thanks, I really appreciate it! Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
