4032 good for 15psi?
I am leaning towards 4032 b/c of the good wear the motors with them have.
I am going push 15psi occasionally at the track, maybe 20 to 30 passes a year and maybe some street runs against the occasional GTR or ZR1. I run E85 on my current set up on 11:1 CR on 10psi with no issues on stock LS2. Want to go up to 14.7 psi so experienced input is welcome. Thanks
I had mahle 4032 and i had piston failure ring land broke at 6 psi,changed to 2618 and no problem,i didn't have the best tuner at the time.
Ring land is .250'' on 4032 mahle and .300'' on 2618 mahle
I just witnessed one let go at 10 psi, only 6 deg timing, 10.8 afr, good coolant and intake temps, no det/knock and was only in boost for a couple of seconds.....
My own car survived a couple of yrs at 12 psi without any issues..
Piston below is the Autotec I have been using.
