Put my car on the rollers today, timing/plug question
Basic rundown of the setup:
Stock shortblock w/ 110k miles
Stock 317 heads with Patriot Dual Springs
LS6 Cam
Truck manifold turbo setup with a TC76 at 10#'s, Ebay intercooler, etc etc
Fuel is single intank 255 with a hotwire kit and 60# injectors
Good news is the car made corrected 575 rwhp and 601 ftlbs and backed it up with a 578 rwhp and 595 ftlbs. Uncorrected was 600 rwhp and 627 ftlbs.
Bad news is the car pulled 2-3 degrees at approx 4100 rpm on the first pulls, and when I pulled that out of the timing table, it pulled it at 5100 on the next pull. This is odd because it has NEVER knocked on the street or track over the past two years even in the dead of summer. WOT timing was at 15 degrees. I pulled 2 degrees out between 3800-5200 be safe until I can do some hwy pulls to verify what is going on. Might have been vibration or a extra load on it from the eddy on the dyno.
Currently I've been running TR6's gapped at .032 which I change approx every 1000-1500 miles because I have never had a timing issue. Would there be a benefit to jumping to a BR7EF? I really didnt expect to see any knock on the dyno cause it never knocks on the street and the weather is nice and cold today, but I know I'm pushing this motor hard so I want to make sure it stays happy.
Thanks
I run autolite 103's t .025-.028, change them once a year or so.
What was the AFR like throughout the pull? And what fuel are you using? Sounds like it knocked at peak torque?
In my experience, Mustang dynos seem to push the car harder than the street does. So that makes sense to me.
I agree on the loading, our dyno definitely hits the car harder than the street does.
