New best in the Turbo Firehawk
Old Nov 13, 2011 | 04:34 PM
dschmittie1's Avatar
Default New best in the Turbo Firehawk
Well after a crazy year of sorting out issues and crappy weather I finnaly got a chance to go to a nice track rental and make some hits on very well prepped track at MIR on Friday 11-11
I also want to thank Modular turbo for promptly shipping me an alternator bracket just in time to go to the rental
The set up
Forged 347
Diamond pistons
Callie's I beam rods
AFR 205 heads
Ported Vic Jr
VA speed cam
PT88
Rossler TH400
Yank 3400 stall
MWC rear with 3.25 gears
325 50 15 M&H radial
All passes were on 15psi
First pass off the trailer two step at 3400 rpm
60'- 1.531
330- 4.162
1/8- 6.358
mph- 117.52
1000- 8.073
1/4- 9.597
mph 147.79
Car felt like it bogged a little so I let the car cool down for a awhile and watch a buddy make some passes
Second pass two step at 3800
60'- 1.513
330- 4.121
1/8- 6.217
mph- 117.57
1000- 8.029
1/4- 9.563
mph 146.56
Car still felt like it bogged some on this pass and also hit the rev limiter on the 1-2 shift. Desided to drive over to the scales to see what the car weighs. I was blown away to see the that the car weighs 3620# with me in it. I really though I would have been sub 3500 with my in it.
Let the car cool down for an hour again and bumped the 2 step again to 4100 for my 3rd pass
60'- 1.545
330- 4.190
1/8- 6.321
mph- 116.08
1000- 8.145
1/4- 9.684
mph 146.26
Car left hard and I pulled the shifter halfway back into second on the launch so I pulled it the rest of the way back not wanting to hurt anything. So I shifted into 2nd early
Overall I was happy with my results from the day but I have a few things I wanted to go over before I making any more passes and my buddy I was there with was done for the day as well so desided to pack it up early and go home in 1 peice.
I want to go over the car again good and make at least 1 more trip out before putting the car away for the year.
Here is a video of the last pass
http://www.youtube.com/watch?v=Xy4ATeOylS4
Old Nov 13, 2011 | 05:20 PM
1fast bird's Avatar
Definately looks like you need to relocate the trans brake button off the shifter. That's the reason I put mine on the steering wheel
Car looks good Dan. Leaves nice and goes straight.
Oh yeah, put that thing on a diet!!!!
Old Nov 13, 2011 | 05:30 PM
Wicked69's Avatar
Very nice...and very smooth.
Old Nov 13, 2011 | 05:37 PM
Firehawk441's Avatar
Videos are tough to judge off of, but to me it looks and sounds like your converter is too tight
Congrats on the new best though.
Old Nov 13, 2011 | 05:48 PM
Fbodyjunkie06's Avatar
Do you not ever try to footbrake it up and then go to the transbrake?
Old Nov 13, 2011 | 06:07 PM
Turbo's like tight converters. I am set up to be able to foot brake and build some boost too before getting on the trans brake. I can also still add some timing to it to make it spool faster
Yeah I know the car is going on a diet over the winter. Maybe even the driver too
Thanks
I have just wasn't this day. I was more concerned with working on some other stuff
Old Nov 13, 2011 | 06:14 PM
MUSTANGBRKR02's Avatar
Congrats on the times. Shake it down some more and turn up the boost and see what it does.
Old Nov 13, 2011 | 06:42 PM
ls1curt's Avatar
how much boost are you leaving on?
Old Nov 13, 2011 | 07:01 PM
1fast bird's Avatar
He was leaving around 8 psi.
Old Nov 13, 2011 | 07:21 PM
Yep about 8psi just needs more rpm on the launch for a sticky track like MIR not sure I could launch like that at Cecil
Old Nov 13, 2011 | 08:38 PM
Sorry dude. Guess I don't know too much. Nice job.
Old Nov 13, 2011 | 08:48 PM
Its all good. The tighter converter alows me to load the car more and build more boost on the line. I honestly think my converter could be a little tighter up top. I am only seeing like a 400 rpm drop on the 2-3 shift.
I know I need to spend a little more time working on the tune as I have yet to change my timing tables at all from when the car was procharged. I know I can put more timing to it down low to help spool the turbo on the trans brake
How is your car coming along? I bet that new motor is gonna be nasty
Old Nov 13, 2011 | 09:12 PM
I'll be out in the spring.
Old Nov 13, 2011 | 10:12 PM
krissoto's Avatar
running good man
Old Nov 14, 2011 | 06:53 AM
ls1curt's Avatar
Is that converter a 9.5" or 10.5" 3400? Beacuse my py3400 is very tight.
Old Nov 14, 2011 | 07:00 AM
10.5
It is very tight down low. I just think it could be a little tighter up top. Not sure though. I need to sit down and calculate my slip again
Old Nov 14, 2011 | 09:08 AM
onfire's Avatar
Coal Mining Director
Gotta love turbo Hawks! Killer pass. Which rear bar and springs in the back...looks like you are losing some 60 with some twist.
Old Nov 14, 2011 | 09:31 AM
MIGHTYMOUSE's Avatar
the 60 should be quicker, but cant really put my finger on the culprit.
3600 leave should put you in the 1.4's unless something is slipping
Old Nov 14, 2011 | 09:48 AM
Stock rear springs, BMR drag bar and QA1's all around
The car set up exactly the same with the Procharger and an M6 had gone 1.4's before. Car just feels like it bogs on the hit
This is a little 347 too. I need to work on the tune more as all I have really done it get my AFR's in line no real work on playing with timiing to help things down low.
I am only running 17* on pump and Meth.
I am also debating making the switch to E85 over the winter not sure yet
Old Nov 14, 2011 | 10:03 AM
LS1RedZ's Avatar
Damn it man! Thats moving out!! Makes me want to use these truck manifolds I have and sale this D1SC.
