is this normal wear for a piston skirt?
Old Nov 15, 2011 | 06:28 PM
lmt0705's Avatar
there weiscos, checked the bores today, some spots were opened up to about .0065 from .005 at the buildup. motor had 4k on it and 40-50 dyno pulls on it over 3 seasons.
Old Nov 15, 2011 | 06:39 PM
stevieturbo's Avatar
Originally Posted by Shawn @ VA Speed
actually that is not normal-got one here i just tore apart after 20,000 miles-no wear like that whatsoever.
Not normal, but very common.
Mine was the same after less than 5k. Pistons very badly worn because of the long stroke and lose bore clearance. Wiseco's running a whopping 7thou clearance, which I'm sure didnt help at all.
I'm rebuilding and destroking.
Although my previous JE pistons in a different build didnt suffer the same problem. They did had some marks, but nothing worth worrying about and it had ran for around 10k before I destroyed it.
Old Nov 15, 2011 | 07:53 PM
Fbodyjunkie06's Avatar
Man this is making me have second thoughts on stroking my new motor.
Old Nov 15, 2011 | 09:38 PM
9sectruck's Avatar
same here I may be going back to the stock stroke on my new build, I already have enough problems def. dont need another
Old Nov 15, 2011 | 10:51 PM
lmt0705's Avatar
I hear ya, thinking about trying some short skirt pistons but I don't want to loose stability either
Old Nov 15, 2011 | 11:36 PM
GrahamHill's Avatar
Does that piston use a support ring? Can't tell from the piston. Its an extra ring, goes in with the oil control rings.
