is this normal wear for a piston skirt?
Old Nov 14, 2011 | 11:22 AM
lmt0705's Avatar
Default is this normal wear for a piston skirt?
pulled my motor down today and found this, talked to my local machine shop and they told me this was very common in stroker motors with this size skirt. what are my options? can I reuse them? should I look for a smaller skirt piston?
Old Nov 14, 2011 | 11:23 AM
lmt0705's Avatar
not sure how many short skirt pistons are avalible for us FI guys
Old Nov 14, 2011 | 01:32 PM
dschmittie1's Avatar
I think part of the problem with strokers is the piston is very short because of the stroke.
I was also told by a machinist that a bad tune up and detonation can cause where like that and collapse the skirts (I had collapsed the skirts on a couple pistons in my old motor)
Old Nov 14, 2011 | 08:19 PM
lmt0705's Avatar
Wondering if I should reuse them
Old Nov 14, 2011 | 08:21 PM
tomz28's Avatar
they look like these?
Old Nov 14, 2011 | 08:46 PM
red91z's Avatar
LS1TECH Sponsor
My 404 used to do this real bad. The stroke pulls the piston out of the bottom of the bore too far.
Old Nov 14, 2011 | 08:47 PM
probably no. They should be measured to see if they had the skirt colapse. Looking the way they do I would think they are no good.
Old Nov 14, 2011 | 09:56 PM
lmt0705's Avatar
I'll Mic them up, should I run a short skirt piston?
Old Nov 14, 2011 | 09:57 PM
98Z28CobraKiller's Avatar
Restricted User
Yes, normal for a 4" stroke in a short sleeve block. Do not reuse. Precisely why I am so against the 4" stroke.
Old Nov 14, 2011 | 10:07 PM
tomz28's Avatar
my piston look that way do to the wrong piston to bore clearances
Old Nov 14, 2011 | 11:06 PM
03supercobra's Avatar
It can be helped with the proper piston to bore clearance, proper skirt taper, and finish on the bottom on the cylinder edge. Those skirts looks pretty torn up. I just had my motor apart with a 4" stroke setup and they actually looks pretty decent.
Old Nov 14, 2011 | 11:09 PM
lmt0705's Avatar
Think I'm at .005 clearance. Skirt taper is up to weisco. What piston should I look into.
Old Nov 15, 2011 | 07:18 AM
Shawn @ VA Speed's Avatar
actually that is not normal-got one here i just tore apart after 20,000 miles-no wear like that whatsoever.
Old Nov 15, 2011 | 08:24 AM
lmt0705's Avatar
what would be a guess of whats going on?
Old Nov 15, 2011 | 08:29 AM
lmt0705's Avatar
here is another pic without the flash glare
Old Nov 15, 2011 | 08:55 AM
helicoil's Avatar
Is the bottom of the cylinder chamfered?
Old Nov 15, 2011 | 09:10 AM
lmt0705's Avatar
yes it is
Old Nov 15, 2011 | 03:48 PM
how old are those pistons?
Old Nov 15, 2011 | 04:08 PM
05HD's Avatar
A skirt coating helps in addition to the other things mentioned. That is where GM went when they had skirt scuffing issues on the 3.4L (2.8) V6.
Old Nov 15, 2011 | 04:43 PM
I have had good luck with Diamond pistons, maybe try a set of those on the setup and see if you have better results. I'd check the chamfer, and check piston to wall after the machine work is done.
