Trans am 5.3 turbo build
Old Nov 18, 2011 | 02:43 PM
831jd's Avatar
Default Trans am 5.3 turbo build
my set up.....
1996 trans am
lm7 5.3 stock bottom end
ARP Rod bolts
Ls6 cam
front truck mount
s480 turbo 1.10 ar
Meth injection
victor jr intake manifold
CA 91 pump gas
4l80e
3.27 gears
3600 stall
2 step
Should i run 317 heads or would my comp. just be to low.. or just stick with th 5.3 heads.... i want to run like 12-15psi 600rwhp plus building it for the track 1/4..
thanks for the help
Old Nov 19, 2011 | 09:13 AM
Wicked69's Avatar
I'm sure others will chime in but from what I have been told...if you are only planning that much boost and conservative hp, the stock heads will be more than enough. The cam looks a little on the big side. My cam is considered pretty aggressive and it is a 224/230 .581/.588 114 Yours is even bigger than that. Probably going to need some different valve springs also. I was told the Patriot Gold Duals are nice. That was what I got.
Hopefully, some others will chime in. I am also in the process of doing my first build so take my information with a grain of salt.
Old Nov 19, 2011 | 12:35 PM
pwrtrip75's Avatar
Leave stock heads, works way better and you shouldnt have an issue. I'd skip all the ARP stuff too... that turbo wont make enough power to hurt the stock stuff.
Old Nov 19, 2011 | 07:45 PM
831jd's Avatar
So 5.3 heads it is then and yea I will be putting stronger springs for the cam thanks guys
Old Nov 19, 2011 | 08:55 PM
831jd's Avatar
[QUOTE=pwrtrip75;15640298]Leave stock heads, works way better and you shouldnt have an issue. I'd skip all the ARP stuff too... that turbo wont make enough power ghs around
Old Nov 20, 2011 | 10:21 AM
Taubr Unit's Avatar
Do the Extreme Patroit Golds opposed to the standard ones. They have a higher seat pressure and better for boost. Buy um once and be done for the future.
Old Feb 21, 2012 | 06:49 PM
831jd's Avatar
I have 918 valve springs
Old Feb 22, 2012 | 07:51 AM
Strokinit383's Avatar
Arent 918 springs the beehives? I would run a dual valve spring. That way if it breaks, you wont drop a valve.
Old Feb 24, 2012 | 09:53 AM
slow67's Avatar
Gingervitis Addict
I went with that theory too.....Except mine broke both prematurely on one valve (inners only on 3 others)....didn't fully drop a valvle though (but you could push it down easily with your palm). Enough where it left a mark on a piston.
Old Feb 24, 2012 | 10:23 AM
mpatton's Avatar
Hows an ls6 cam on the big side? Just asking
Old Feb 24, 2012 | 10:33 AM
DavidPHumes's Avatar
It isn't, but valve float becomes a huge issue with boost which is why the need for good springs
Old Feb 24, 2012 | 10:47 AM
godlyxdan's Avatar
seems like a really close setup to mine
Im doing a 5.3 with a stock bottom end with 241 heads for some lower compression
as far as cam choice im going with the LS9 cam to keep cost down low
