Anybody Running 5.60's or Faster At 3300lbs?
I'm curious if anybody is running a 5.60 or faster in the 1/8th. I have a lq4 I want to build and will eventually go to a 370 ci. But for now I want to see if I'm crazy to think I can get there with the lq4 and a turbo. Now I'm sure it can be done but the catch is I have to be at 3300 lbs which to me is heavy but it needs to be done for a class. Is anyone doing this? If so please list your combo.
yea the organization i was looking at has a limit in turbo size for Limited 10.5(78 mm) but not for outlaw 8.5. i wanted to go nitrous but after reading the weight adds and breaks i can be the same weight(3150) If i go small block turbo with a blow thru and no intercooler as compared to a small block single stage nitrous car(3100) and must add 50lbs for additional stages. i can pretty much make more power with a turbo for around the same price as going nitrous so i might aswell do it.
Was an ls2 402 with twin tc76's. Had a good bit more in it, but the tune was a little rich. Never got my goal of high 8's before a rod bearing let go and killed the bottom end. Pretty sure it wouldn't have taken anymore boost to get there, just a better driver. Only got 30 or so passes out of it. In other words I never did get comfortable with that setup.
