TT LS2 dyno - power falling off
heres what I got..
This was at 10psi peak and fell down to 4psi at the end (due to a bad boost controller). I did a pull right after with a different boost controller, putting it to 10psi peak and 8psi all the way through and made LESS horsepower..
I have double springs rated to .655 and the cam is a 228/222 .5xx .5xx 114.5. Also have double roller chain, BR7EF's at .030, GT35R's.
AFR is fine. Timing is 13 degrees.
Coils maybe? I feel like the car should have made ALOT more power out of 10psi (torque wise). Graph is at smoothing 3. Looked worse at 5....
This is a graph of a car that has almost an identical setup as mine, he has smaller turbos.
obviously from my graph, something is wrong
my AFR is perfect but I have not checked full pressure. I assume its fine because of the AFR, but who knows..
I noticed recently my Inj B1 and Inj B2 msec is not the same. B1 is .3 higher..? older logs show it was not like this before I messed with the cold side awhile back.
Thanks for all the input.
With a twin turbo with half of the exhaust flow and 4 cylinders independently having their own turbine, you do not need a reverse split camshaft.
Reverse splits are band aids to help with backpressure issues or issue during the exhaust stroke.
With a twin setup and if you selected the correct turbines, why would you need to open and close the exhaust valve that way?
Again, I still say it is the wrong cam. Of course some guys will chime in and say it will work, but guys do sh*t all the time that is not optimal.
Bozz
Bozz
