supercharged 5.3
Old Nov 25, 2011 | 07:57 AM
fowl55's Avatar
Default supercharged 5.3
This is my first post , I am new to the LS engine so here we go . I am building a 55 chevy with an art morrison chassie and would like an ls engine in it . I will be getting a 5.3 out of a crashed 1/2 ton truck it only has 7000 miles on it for 500 bucks . what I would like to do is put a supercharger on it like a whipple or a maggie . I know its not the ideal engine to start with but what kind of power can be made and is there anyone that has a tune . Like was stated its in a 55 chevy two door post . so I might need the computer to run it also any input would be nice . would like 500 to the wheels . am I dreaming .
Old Nov 25, 2011 | 08:30 AM
lmt0705's Avatar
500 should be doable with the right supporting mods, get the computer and wiring harness out of that truck also, it will save you a bunch of headaches and money. while your there take the transmission to!
Old Nov 25, 2011 | 08:49 AM
LSCustoms's Avatar
computer, wire harness (as un cut as possible), gas pedal and pedal module (if drive by wire), fuse block under hood (will make wiring it up a breeze)...
and yes 500 hp is very do-able
Old Nov 25, 2011 | 09:20 AM
Gregory's Avatar
Go to the Performance Trucks tab on the top of the page and look up 5.3 engines under the forced induction section. Some guys make amazing power with stock internals.
Old Nov 25, 2011 | 12:38 PM
Tzion_ben_Arthur's Avatar
welcome and good luck with the build. I agree with the others, 500 is well within reach.
Old Nov 25, 2011 | 01:26 PM
fowl55's Avatar
just got back with the engine , got all the wiring and the trans it all looks great .
Old Nov 25, 2011 | 02:03 PM
Kory 88Iroc Lt1's Avatar
congrats on a good score. I'm currently also looking for info on this. I'm building a 5.3/t56 s10. I plan on adapting a vortech strim kit I have left over from a previous project. my only problem is running the blower with the stock serp belt. I'm wondering about accessive belt slippage.
Good luck with your build.
Kory
Old Nov 25, 2011 | 04:43 PM
1_Bad_82ttCamaro's Avatar
What kind of boost are you going to try to run with that S trim??? I have a 99 chevy 5.3 with a sq trim and run 10psi and have no problems. With ported heads and a small comp cam it put down 485 rwhp through the 3000 stall yank and 4l60e.
Should be no problem to hit 500hp to the wheels. Nitrous goes on mine as soon as I can afford it
Old Nov 25, 2011 | 04:53 PM
I was thinking 10 ro 12lbs. Did you do anything special to you drive system besides pinning the balancer?
Thanks,
Kory
Old Nov 25, 2011 | 04:59 PM
Nope, I pinned the balancer and I made sure that I bought a good belt. I will only have trouble with it when I clean up the engine bay and get armoral on the belt. It is my DD and my tow rig, I trust it completly.
Old Nov 25, 2011 | 05:02 PM
Thanks for the info. I've been concerned that belt slippage would be a major problem. Now it makes me want to get this thing finished asap.
Kory
Old Nov 25, 2011 | 07:34 PM
fowl55's Avatar
now I need to know who has the best supercharger , as well as the best Kit for the money .
Old Nov 25, 2011 | 09:58 PM
Black98s10's Avatar
Hey Kory, what about relocating the idler or adding another to get more belt wrap on the blower
pulley? I think next summer, when our s10's are done, some friendly runs between us will be in order.
Old Nov 26, 2011 | 09:04 AM
I was thinking about the extra pully for more belt wrap. That seems to be a common solution to the problem on performance trucks.
We could run them in the spring. that would be cool.
Kory
